Old 02-08-2011, 01:14 PM   #1 (permalink)
Unhappy [SOLVED] Beeps once, Beeps twice, no video signal...
Hi all... I'm new here and I already have a problem...
Okay, so i just got back to NY where i left my old PC for over a month now... I re-assembled everything [including HDDs, Optical Drives and GFX card] ... I took them to India for the last month...
Everything worked FINE in India... But here after I assembled everything, I don't get video signal... First I got the POST beep... but no signal... couldn't tell if it was loading the OS... but now... I get two more beeps after [much quicker] after the POST beep... Don't know what that means...
It's like >> Computer turned on >> Fans whoosshh >> Beep [hopefully POST] >> Pause >> BeepBeep [No Idea ] >> DEAD O_O ...
At this point [the DEAD point], Computer turns off by tapping power button, indicating its still in BIOS... and Ctrl+Alt+Del works... restarts the ****... and same thing again...
I tried switching RAMs, using them independently... no good...
I tried clearing CMOS, resetting BIOS... no good...
I hardly suspect that the video card is faulty, 'cause I used the same thing for a month back in India...
The monitor itself is working, I plugged it in to my laptop, and it works FINE...
My computer knowledge is decent, and i can do some messing around once you guys tell me to... So here's my problem... Hope I get answers... Without my baby, I'm half dead... So please help...
Computer Config:
ASUS M4A77T/USB3 motherboard
AMD Phenom II x4, 965BE, 3.8 GHz [overclocked]...
2 Corsair RAMs [ 2x 2GB = 4GB ]
NVIDIA 9400GT, 1 GB gfx card... connected with analog cable to a 20" LG monitor...
2 optical drives [1 SATA II, 1 IDE connected]
3 HDDs [2 SATA II = 1.25TB, 1 IDE = 40GB]
~650W PSU with active PFC...
ohh and one more thing... HELPPPP!!!
ezio93 is offline   Reply With Quote
Old 02-08-2011, 04:11 PM   #2 (permalink)
mithun_mrg's Avatar
Default Re: Beeps once, Beeps twice, no video signal...
Try using the Mem ok button
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 02-08-2011, 04:18 PM   #3 (permalink)
Already did.... that was the first thing I did... it just reboots and then the same thing....
Old 02-08-2011, 09:37 PM   #4 (permalink)
It looks as if your gfx card is defective. Unfortunately your mobo doesn't have an onboard GPU, so you can't try that. The best way to find out is with another card. Is there one you can borrow?
BTW, it's best to disconnect your HDD while you're trying out various ideas.
pimpom is offline   Reply With Quote
Old 02-08-2011, 09:59 PM   #5 (permalink)
Level 96 Headbanger
DeSmOnD dAvId's Avatar
Yup, likely onboard video adapter fault. Try with another card or get a new/replace existing motherboard.
"Words meant to dwell in darkness shall never see the light of day.
Words can be broken, so can bones. Execute the mandate." :twisted:
Steam : DeathMetal
Garena : death_metal27
My Blog : The Pandemonium
(Latest Post : Where does music come from?)
Guitar gear : GB&A (acoustic), ESP LTD-M50 (New :twisted:), Roland MicroCube Amp.
DeSmOnD dAvId is offline   Reply With Quote
Old 03-08-2011, 12:18 PM   #6 (permalink)
Thanks guys for replying so quick...
@ pim pom and Desmond...
I took it into account... but can't be sure to replace anything cuz it can also be the PCIe slot... so if my gfx card is not responding... cud it also be that my PCIe is faulty?? well, I used my gfx card back in india like 3 days ago... it ran fine...
i just cant be sure... and i dont have a spare card with me...
and yesh, i disconnected my HDDs when i was testing stuff......
btw... what about the two POST beeps?? i was wondering it could have some answers??
Old 03-08-2011, 03:55 PM   #7 (permalink)
Level 96 Headbanger
Try removing your card and try the onboard video adapter. If there's no problems, then definitely there's some problem with your card. You can test with a spare card whether the problem lies with your card or the slot.
Steam : DeathMetal
Old 04-08-2011, 03:07 PM   #8 (permalink)
looks like ur graphics card is dead. it can fail anytime. i have one fail on me when i rebooted..working few mins before..then it fail suddenly when i reboot.
the least u can do..try to clean the graphics card connector using an eraser.and pray..if it doesnt work then u have to sent it for repair or buy a new one
realdan is offline   Reply With Quote
Old 05-08-2011, 07:38 AM   #9 (permalink)
@ Desmond... my mobo doesn't have an onboard video adapter... so can't check that...
@realdan... Yes, I guessed so... it's pretty old anyway... gotta ask my dad for a new one... [not gonna be easy]...
But i still don't understand what the beeps mean...
yeah... but anyway thanks guys... appreciate the help... let's see what Best Buy says... taking the whole box with me to the store today... XD
will let you know...
[EDIT]
Well, Best Buy dude confirmed that my graphics card is dead.... gonna change it soon....
Thanks for all your help guys...
Signing off... [How do you mark this as solved?]
