Old 01-08-2011, 09:05 PM   #1 (permalink)
VIP
RazorbladeXtreme's Avatar
Question Intel HD Graphics with Dedicated Graphics Card
This question might've been asked multiple times but I can't figure out what exactly would happen to processor graphics in the presence of Dedicated GPU.
My laptop is going (waiting for stupid sales representative to confirm the transaction) to have Intel i7-2630QM 2.00 GHz and NVIDIA GT 540M 2GB.
Would processor graphics be ever in use considering the presence of GPU ? Would both be usable simultaneously / as needed or will I be able to make them work separately using Hardware profiles ? Might processor graphics also be available in situations when GPU drivers are not installed (Linux) ?
Twitter: twitter.com/SharmaTushar
Facebook: facebook.com/tushar.sharma
RazorbladeXtreme is offline   Reply With Quote
Old 01-08-2011, 09:20 PM   #2 (permalink)
Manchester United <3
Ishu Gupta's Avatar
Default Re: Intel HD Graphics with Dedicated Graphics Card
You can switch manually.
So you can use the HD3000 while you are using Internet, movies etc and switch to the GT540M while gaming.
You have to use the Nvidia software to select which applications use which card. The card will detect the applications and switch to the appropriate card as per your settings.
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
Ishu Gupta is offline   Reply With Quote
Old 01-08-2011, 09:48 PM   #3 (permalink)
VIP
So Nvidia will allow this without rebooting ? Nice, I see long battery life
Old 01-08-2011, 09:52 PM   #4 (permalink)
Ishu Gupta's Avatar
Yes .
5hrs on Intel and 2.5 hrs on Nvidia.
Old 02-08-2011, 01:24 AM   #5 (permalink)
the m0nk who sold his PC!
MatchBoxx's Avatar
By any chance, are you talking about Dell XPS 15?
you sure buddy??? Dell XPS 15 doesn't have nVidia Optimus Technology, nor it has Z68 chipset to enable Lucid Virtu, afaik...i may be wrong. Clarify my doubts please.
Intel i5-2400 || ASUS P8H77-M || G.Skill RipjawsX 8GB (4GBx2) || MSI HD6850 Cyclone PE || Corsair GS600 || Cooler Master Elite 431(Side Panel) || Dell ST2220L || Edifier C2 || APC 1.1 kVA || Seagate GoFlex 1TB
(WBUT semester routine announced. I'm OFF for the time being.)
MatchBoxx is offline   Reply With Quote
Old 02-08-2011, 03:16 AM   #6 (permalink)
Ishu Gupta's Avatar
Check this
Dell XPS 15 Laptop Details | Dell India
its says 'with optimus'
