Old 29-07-2011, 12:32 PM   #1 (permalink)
Simply.. Evolution !!
TheMost's Avatar
Default File copying prob !
U saw that ?? This is with my PC - Specs in my signature
I have a dell Studio 15 and it takes file copying at 15MB/sec ( I use the same teracopy there also )
copy was from HDD to Pen drive
Why is it so ???
Is there something wrong with my PC ??
I don't have any malware !
| Core2Quad Q6600 @ 2.40GHz, 4GB RAM |GeForce GTX 260 |
:???: BUSY BEEE :?
TheMost is offline   Reply With Quote
Old 29-07-2011, 12:43 PM   #2 (permalink)
Thumbs up Re: File copying prob !
Hi bro its me mak better u try to uninstall tera copy and reinstall tera copy if it does not fix the problem then install the previous version of tera copy then it will work smoothly without ny issues........have a nice day!!!!!!!!!!!! AND ALSO U CAN GET ALL OLDER AND LATEST VERSIONS OF TERA COPY ON WWW.FILEHIPPO.COM
MAK5577 is offline   Reply With Quote
Old 29-07-2011, 02:05 PM   #3 (permalink)
saswat23's Avatar
Default Re: File copying prob !
IMO the file is corrupted..
i5-2400 | P8H67M-EVO | DRW 24B3ST | WDC Blue 500GB | VENGEANCE 4GB DDR3 | FSP SAGA-II 500W | Zebronics Aviator | DELL IN2020M | MS Wired 500 Combo | Creative A-35 | iBall Rocky Headset
saswat23 is offline   Reply With Quote
Old 29-07-2011, 02:17 PM   #4 (permalink)
TheMost's Avatar
^ u mean tera copy ??
:???: BUSY BEEE :?
Old 29-07-2011, 02:18 PM   #5 (permalink)
First of all, no one can ever be sure that they don't have any malware. Just because your AV doesn't find any, it doesn't mean that you don't have them. I'm not saying that your problem is caused by malware, but it's something to keep in mind.
You left out one piece of info: What are the source and destination of the file you're copying? Are they both in the same HDD, HDD to HDD, thumb drive to HDD, DVD to HDD, etc.?
Even 14 MB/s is quite slow. My configuration (AMD 7750+ & 4GB) is roughly comparable to yours and I get 40-55 MB/s copying partition-to-partition within the same HDD. Copying to and from thumb drives and CD/DVDs are much slower.
AV progs and file fragmentation can slow things down, but not to the speeds you're getting. Assuming that you're copying within the same HDD, the slow speed could be caused by a bad sector, a corrupt file system, some background task with a high CPU usage. What is your CPU usage when idle and while copying? Are other tasks also running slow?
pimpom is offline   Reply With Quote
Old 29-07-2011, 02:48 PM   #6 (permalink)
TheMost's Avatar
^ I completely agree with u ...
Mistake is mine - I forgot to mention that the copy was from HDD to Pen drive !!
Regarding malware - I ain't dependent on AV solution and know what processes is running !
:???: BUSY BEEE :?
Old 29-07-2011, 03:25 PM   #7 (permalink)
Fullbring
Zangetsu's Avatar
Copying speed depends on pendrive write speed...
& 15MB/s is average speed..
also depends how old is the pendrive
I get 30~35MB/sec while copying
Old 29-07-2011, 03:34 PM   #8 (permalink)
Dust in the Wind
Skud's Avatar
15MB/s is average for a USB device. Try to use the Windows file copy and take a note of the speed.
Gaming Rig:
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 || Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
C2D E7400 || Gigabyte EP45-DS3R || 2x2GB DDR2 800 || 9TB || MS Wireless Desktop 2000 || Gigabyte 5770 || Samsung 32" || Seasonic SII 520W || Silverstone LC10
Samsung Galaxy R I9103
Will be off/irregular for a month...
Skud is offline   Reply With Quote
Old 29-07-2011, 03:36 PM   #9 (permalink)
Copying to a thumb drive at 5.3 MB/s is not too slow. It's not super-fast, but it's well within reason. What makes it difficult to judge the speed is that thumb drives differ widely in speeds. I've tested drives at write speeds from less than 1 MB/s to >15 MB/s for the same file. Even different samples of the same model differ in speed.
Another thing is that write speed is always lower than read speed for the same drive. If you get a read speed of 14 MB/s and a write speed of ~5 MB/s with the same unit, that's within the normal range for thumb drives.
Still another thing is that speed can vary widely between a single large file and a number of small files.
Old 29-07-2011, 03:43 PM   #10 (permalink)
TheMost's Avatar
My prob is y i get low speeds in my PC when i get 15 MB/sec in my laptop ??
:???: BUSY BEEE :?
Old 29-07-2011, 03:46 PM   #11 (permalink)
^Are you sure you're not writing with your desktop and reading with your laptop?
Old 29-07-2011, 03:56 PM   #12 (permalink)
TheMost's Avatar
Oh that makes a difference ah ?
ya i'm talking like that only ..
I get 17MB/sec on PC while i read !
Sorry guys !
:???: BUSY BEEE :?
Old 29-07-2011, 04:45 PM   #13 (permalink)
No prob. We all live and learn.
Old 29-07-2011, 04:50 PM   #14 (permalink)
TheMost's Avatar
^ Thanks for taking this easy pimpom ..
So kind of u .
:???: BUSY BEEE :?
Old 29-07-2011, 04:52 PM   #15 (permalink)
Racing 24X7
NitrousNavneet's Avatar
does 'tera copy' copy the file faster then default copier ?
"Those Who Are Afraid OF Falling Will Never BE Able To Fly"
>>Intel dual core 2.20 GHz
>>Asus P5GC-MX/1333
>>2Gb Ram
>>500Gb Seagate
>>Asus Eah4350 Silent Graphics Card
>>Windows 7 ultimate X64
Please
Help
NitrousNavneet is offline   Reply With Quote
Old 29-07-2011, 04:56 PM   #16 (permalink)
TheMost's Avatar
Not like that i believe but it has many features than default ..
:???: BUSY BEEE :?
Old 29-07-2011, 05:03 PM   #17 (permalink)
Depends. For small copying tasks, TeraCopy can actually make things slower, mostly because of the time it takes to load the prog. But for large amounts of data, it's definitely faster than the Windows copy tool.
TeraCopy has an option to make it the default copier or not. I turn it off as the default and turn it on when I want to transfer large amounts of data.
Old 29-07-2011, 05:07 PM   #18 (permalink)
Dust in the Wind
Skud's Avatar
Or you can tinker with the settings and turn on the scroll-lock to turn teracopy off.
Gaming Rig:
HTPC Rig:
Old 29-07-2011, 05:39 PM   #19 (permalink)
Fullbring
Zangetsu's Avatar
TeraCopy is way better than defualt copy process in windows XP but
in Windows 7 almost similar.
Teracopy claims to give a boost in speed while copying...
but it has nice features like queuing,resume etc.
For Windows XP users it is highly recommended.
but windows 7 users its optional.
Old 29-07-2011, 07:27 PM   #20 (permalink)
Dust in the Wind
Skud's Avatar
Try ExtremeCopy. It's supposedly better than TeraCopy.
Gaming Rig:
HTPC Rig:
Old 30-07-2011, 04:08 PM   #21 (permalink)
Racing 24X7
I am using SuperCopier2 (given in Dgit DVD)
>>Asus P5GC-MX/1333
>>2Gb Ram
>>500Gb Seagate
Please
Help
Old 30-07-2011, 04:22 PM   #22 (permalink)
Dust in the Wind
Skud's Avatar
How about it's performance?
Gaming Rig:
HTPC Rig:
Old 30-07-2011, 09:48 PM   #23 (permalink)
TheMost's Avatar
READ !
(also the comments)
:???: BUSY BEEE :?
Old 31-07-2011, 08:41 PM   #24 (permalink)
Racing 24X7
Nice ,
Not so much fast ,But Faster Then Xp's default .
Originally Posted by TheMost View Post
READ !
(also the comments)
There are so many names.
???= CONFUSED=??? in selection.
>>Asus P5GC-MX/1333
>>2Gb Ram
>>500Gb Seagate
Please
Help
Old 31-07-2011, 11:45 PM   #25 (permalink)
Democracy is a myth
rhitwick's Avatar
I'm not sure if people are still discussing about TheMost's problem, but as per my experience I've seen that file copying to pendrives is typically slow comparing to other USB HDDs
I've 3 external HDDs 1TB,2TB and 3TB. I get avg. 35 to 40MBps in each of them.
But for pen drives (2-8GB sized ones) the avg speed is close to 8-10MBps.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now   Reply With Quote
Old 01-08-2011, 12:46 AM   #26 (permalink)
pulkitpopli2004's Avatar
^^yeah pendrives usually gives this much speed only..
15MB/s thats wht i get with my PD.. its transcend 8gb..
and from HDD to HDD its 30 to 60MBps max..
I'd explain it to you, but your brain would explode... Trust me :hot:
i5 760, Asus P7P55D-EVO, Zotac GTX 460, VX550, Win7 64bit,4GB RAM @1600MHz, WD 500GB Caviar Black
pulkitpopli2004 is online now   Reply With Quote
Old 01-08-2011, 10:37 AM   #27 (permalink)
Just try out a few of those mentioned by name. In cases like this, it's more a matter of what suits you than of which one is the absolute best.
E.g., Prog 1 may be slightly faster than Prog 2, but you may find Prog 2 more suitable to your usage habits, in which case you should go for Prog 2 and just ignore the benchmarks. If someone else prefers Prog 1, then he should use it. That's all, really.
What reviewers and other users say should be used as a guide, but you should not feel compelled to follow their preference.
Old 01-08-2011, 01:19 PM   #28 (permalink)
TheMost's Avatar
My problem is solved ! !!!
:???: BUSY BEEE :?
Old 01-08-2011, 01:44 PM   #29 (permalink)
Fullbring
Zangetsu's Avatar
^How...it may be helpful for others
