Originally Posted by MegaMind
Avail. in almost all electrical shops.. Like this,
Would go and look for one.
Originally Posted by pimpom
Besides the obvious mechanical difference, the main electrical difference between type G and type D is that type G has a fuse built in. Your PSU, spike guard and UPS all have their own fuses, so the plug's fuse is not essential.
You can use a plug adaptor as suggested by Zangetsu or simply replace the power cord with one that has a type D plug.
Another option is to use a spike guard with a universal socket. Many spike guards come with those.
I actually have type d power cord but would still look for adapter.Thanks for help.
Zangetsu,Pimpom and Megamind thanks a lot for help.
