Old 25-07-2011, 07:30 PM   #1 (permalink)
prateek007391's Avatar
Cool Computer Freezes Randomly
My Computer Configuration is
MoBo - MSI 7211
Intel Pentium D 2.8Ghz Processor
2 x 1GB RAM
250 GB Barracuda HDD
450W Powersupply
Windows XP SP2
Earlier I had Windows XP SP3 Installed and all was working fine except that the things were a bit laggy. So I though A full fledge reinstallation would do good to me. However After installation of Windows XP SP2 my system started to freeze very very frequently. Sometimes during boot, after 5 Minutes, 10 Minutes 30 Minutes there is no schedule no sequence, I even tried upgrading it to SP3 but its not working, I tried to repair my System with Windows XP CD but no remedie its still restarting.
However The safe mode is working fine, I tried everything is safemode and it works fine there no hangs no Freezing. I am actually posting this thread from same computer working in Safe Mode.
Plzz What should I do now. ????
prateek007391 is offline   Reply With Quote
Old 25-07-2011, 09:59 PM   #2 (permalink)
Default Re: Computer Freezes Randomly
It could be one of a number of things. Instead of trying to tackle all possibilities, let's concentrate on the RAM first. Remove your RAMs and put in only one stick, then boot your computer and see if it's stable now. When trying out RAMs, from practical experience, I find that removing them and inserting them again works better than simply pushing them hard when they are already seated in the slots.
You could also test them with memtest86.
Another thing you can do is to uninstall your drivers and see if your computer is now stable. If it is, reinstall the drivers and try it out again.
pimpom is offline   Reply With Quote
Old 25-07-2011, 10:07 PM   #3 (permalink)
Manchester United <3
Ishu Gupta's Avatar
Re-install. Probably your drivers.
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
Ishu Gupta is offline   Reply With Quote
Old 27-07-2011, 01:07 PM   #4 (permalink)
I tested my RAM's with Memtest no error found.
Then I removed One of the RAM, computer didn't start, Then I inserted another RAM computer worked fine but eventually hangs after a considerable long period of about 30minutes or so. Yes It does work longer then earlier. But still it freezes
I have now Wiped out my System Partition and Reinstalled the Windows XP. Will see if the problem persist. Though Without the driver the Computer is running well no lags, no Freezing problem.
I think the problem is because of Drivers.
Will keep posted.
Old 27-07-2011, 01:46 PM   #5 (permalink)
Fullbring
Zangetsu's Avatar
download the latest drivers
Old 28-07-2011, 10:22 AM   #6 (permalink)
It seems that Computer is not freezing very quickly (Yes its still freezing) But now It works for 1 or 2 Hours.
I have updated all my drivers from MSI website. What it can be?
The Freezing is not App specific. It hangs anytime, while working on Internet or working on MS word. Still can't get it. What hardware might be creating trouble.
Old 28-07-2011, 10:57 AM   #7 (permalink)
Fullbring
Zangetsu's Avatar
Could be any...RAM,HDD,Proccy etc.
most probably RAM.
Check again..& note the RAM which caused no booting...it happend with me
also.my one RAM was faulty.
Old 30-07-2011, 11:58 AM   #8 (permalink)
I tried Six different Rams on My Computer. Its still not working it starts for just few Minutes and then freezes.
Again the problem started I think the RAM slots are not working.
Old 30-07-2011, 05:08 PM   #9 (permalink)
I once had this problem, it was due to faulty powersupply.
casual_gamer is offline   Reply With Quote
Old 30-07-2011, 06:33 PM   #10 (permalink)
The Warchief
Kola2842's Avatar
same problem was with my friend pc and reson was faulty power supply.
Kola2842 is offline   Reply With Quote
