Old 24-07-2011, 03:48 PM   #1 (permalink)
Designer Here
techking_dinesh's Avatar
Default can i use this ram ?
Hello,
I bought a new pc with follwing config
i7-2600k
asus v pro MB
corsair 4gb ddr3 1600mhz ram
rest is nt needed
My friend gave me a 2gb ddr3 ram stick of simtronics brand. local brand.. it is 1333Mhz..
can i use it up in ma config to make it 6gb ??
or there will be problems as the frequencies r different ??
js wanted to knw this noob stuff
thnx
techking_dinesh is offline   Reply With Quote
Old 24-07-2011, 04:13 PM   #2 (permalink)
Default Re: can i use this ram ?
You can use them no doubt but its better not to mix different brands.
Also the 1600 MHz RAM will be underclocked to 1333 MHz
Old 24-07-2011, 04:28 PM   #3 (permalink)
The Assassin
Cybertonic's Avatar
Sorry late post. thetechfreak has already answered the query
Nothing is true. Everything is permitted.
Steam : $/@$]-[ DK
http://steamcommunity.com/profiles/76561198047340352
Cybertonic is offline   Reply With Quote
Old 24-07-2011, 04:36 PM   #4 (permalink)
Super Moderator
asingh's Avatar
the 1600MHz will auto downclock to 1333Mhz. I would rather not mix grade of ram. You have high end Corsairs, let them run separate. Plus you will loose dual channel.
asingh is offline   Reply With Quote
Old 24-07-2011, 05:41 PM   #5 (permalink)
Designer Here
^ dual channel ??
i m sorry , i did nt understood those details.. jus want to know whether it is advisable or not..
moreover in d bios my ram is already running to 1333mhz .. it is set on auto.. but the ram automatically comes to 1333mhz
secondly i have that 2 gb as spare.. no use..
js wanted to knw if adding it is advisable and will improve my performance or nt ?
i m very happy with my 4gb though.. bt still keepin 2 2gb in some cupboard then y not in d system ??
so my doubt ..
Old 24-07-2011, 07:31 PM   #6 (permalink)
Super Moderator
asingh's Avatar
Will not make a world of difference. I would not.
Old 24-07-2011, 09:38 PM   #7 (permalink)
Technoholik !!
Tech&ME's Avatar
In simple words.
Don't put that 2gb ram in your system.
Enjoy what you have in your system and forget about that 2gb ram.
you can sell it in the bazaar section of this forum.
[Desktop]
[Laptop]
Tech&ME is offline   Reply With Quote
Old 24-07-2011, 11:51 PM   #8 (permalink)
Check the voltage of your rams, ideally should be 1.5V
Faun is online now   Reply With Quote
Old 25-07-2011, 09:55 AM   #9 (permalink)
Your PC is new isnt it?
Dont put that friends RAM onto your PC. Atleast not till the warranty of all your components run out
Its best not to mix brands and different speeds
Old 25-07-2011, 08:27 PM   #10 (permalink)
Adam young
sukesh1090's Avatar
for right now 4gb ram is more than enuff,so better to leave it alone and don't use that ram.about 1333MHz in bios change from auto to 1600 if u have any option like that,if not then don't touch it.
:razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
sukesh1090 is offline   Reply With Quote
Old 25-07-2011, 08:47 PM   #11 (permalink)
saswat23's Avatar
Yes, just try to sell that DDR3 1333MHz RAM. Ifin future you want to upgarde then better opt for 4GB of the very same model you are using now so that your PC runs in dual channel w/o any issues.
BTW if you are running your 1600MHz RAM at 1333MHz then you can easily OC it to 1600MHz to get the best performance from your RAM.
i5-2400 | P8H67M-EVO | DRW 24B3ST | WDC Blue 500GB | VENGEANCE 4GB DDR3 | FSP SAGA-II 500W | Zebronics Aviator | DELL IN2020M | MS Wired 500 Combo | Creative A-35 | iBall Rocky Headset
saswat23 is offline   Reply With Quote
Old 25-07-2011, 11:02 PM   #12 (permalink)
MegaMind's Avatar
I dont think so..
i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - 1TB 7200.12 - 9800GT - CM M600 - NZXT Gamma - XONAR DX + VS4121/XB500 - OptX AW2210
MegaMind is offline   Reply With Quote
Old 25-07-2011, 11:23 PM   #13 (permalink)
Manchester United <3
Ishu Gupta's Avatar
Originally Posted by MegaMind View Post
I dont think so..
Dual channel works for 2 or 4DIMMS.
And its pointless to try to sell that RAM. You can buy a new Corsair for Rs800.
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
Ishu Gupta is offline   Reply With Quote
Old 25-07-2011, 11:50 PM   #14 (permalink)
MegaMind's Avatar
I had it working on dual channel with 3 RAMs in my previous rig(Q8400+DG43GT)...
Old 26-07-2011, 12:53 PM   #15 (permalink)
Fullbring
Zangetsu's Avatar
don't be greedy that u will get 6GB RAM...
they wont make any performance difference & also there will always be a risk of RAM corruption....who knows
@all: can we use 4RAMs in Dual Channel mode?
also is there tripple channel?
Old 26-07-2011, 01:00 PM   #16 (permalink)
MegaMind's Avatar
Yes, 4RAMs in Dual Channel mode..
LGA 1366 uses triple channel arch.
@techking_dinesh, BSODs occur wen u mix up RAMs of diff. latencies.. Not sure abt diff. frequencies.. Still Better to stay with 4GB..
Old 26-07-2011, 01:26 PM   #17 (permalink)
Super Moderator
asingh's Avatar
The OP here, cannot tri-channel.
Old 26-07-2011, 02:49 PM   #18 (permalink)
Manc
xtremevicky's Avatar
Sell that 2Gb and Get a new 4Gb .
If you like the Post , There is a Rep Button ,
If not then Understand that, There are people with different Opinions !
xtremevicky is offline   Reply With Quote
Old 30-07-2011, 06:28 PM   #19 (permalink)
Designer Here
alright.. removed d 2gb.. now only 4gb dr3 in my system !!
doing its mm test and stff again to see if this works well or not
