Old 23-07-2011, 05:17 PM   #1 (permalink)
Question SilverStone TJ10 questions
Hello,
I just ordered a SilverStone TJ10. However, I am worried about a couple of things:
1. Does the curved pull-out handle for the slide-out motherboard tray cause obstruction while connecting a DVI monitor to the inner DVI port on a graphics card such as the Radeon HD6970? (It has 2 inner DVI ports, one below the other)
2. Will a multi tip screw driver pass through the hole on the side metal strip that provides access to the screw on add-on cards? I heard that the hole is too narrow and only screw drivers with thin diameters will go through the hole. Is this side metal strip removable?
Thanks,
Trinanjan.
bhanja_Trinanjan is offline   Reply With Quote
