Old 19-07-2011, 09:15 PM   #1 (permalink)
Default JuneJuly 2011 DVDs not working
Hi,
none of my June/July 2011 DVDs are opening. I tried it on two different pcs with xp/vista/win 7. It is taking ages and not opening. The DVD drive keeps on accessing it. When I complained Digit people sent me replacement. With the new DVDs also same problem?
Please tell me what could be the problem?
gramesh is offline   Reply With Quote
Old 19-07-2011, 09:29 PM   #2 (permalink)
Default Re: JuneJuly 2011 DVDs not working
Send an email to help@thinkdigit.com
Make the subject- CD/DVD to ensure it reaches the right person
Old 19-07-2011, 09:41 PM   #3 (permalink)
The Assassin
Cybertonic's Avatar
I think its a common problem with Digit DVDs . I have faced it too. I think it has to do with digit providing dual layer DVDs and older optical drives having trouble reading them.
Nothing is true. Everything is permitted.
Steam : $/@$]-[ DK
http://steamcommunity.com/profiles/76561198047340352
Cybertonic is offline   Reply With Quote
Old 20-07-2011, 04:35 PM   #4 (permalink)
I sent a mail and Digit sent me replacement as already mentioned in my post. The same problem continues, what could be the cause?
how did your problem got solved?
Old 20-07-2011, 04:37 PM   #5 (permalink)
How old is the DVD drive? Does it support DUAL LAYER DVD?
Old 21-07-2011, 11:07 PM   #6 (permalink)
about two years. How to check that it supports Dual Layer DVD?
