Old 18-07-2011, 02:24 PM   #1 (permalink)
Question [Solved] USB port voltage
We use the usb port to charge a lot of our devices na... could someone tell me what is the exact output voltage of the usb port..?
Nakul is offline   Reply With Quote
Old 18-07-2011, 02:27 PM   #2 (permalink)
Default Re: USB port voltage
USB - Wikipedia, the free encyclopedia
Old 18-07-2011, 11:53 PM   #3 (permalink)
Project Halcyon V2.0
tkin's Avatar
@ico, good enough, close this.
Project Halcyon v2.0:
[i7 2600k|Asus Z68 VPro|Vengeance 2x4GB|MSI GTX580 Lightning]
[TX 750v2|Seagate 500GB+WD Cav Black 1TB|CM HAF 912 Adv]
[Logitech G110|G500|Adata/750GB+WD/500GB USB 3.0]
[APC 1100VA|XBox 360 Controller|Noctua U12PSE2]
[Siberia Soundcard(Xear 3D)|Koss Portapro|FiiO E6]
[Audio Technica M35|PL30/EOL'ed]
tkin is offline   Reply With Quote
Old 19-07-2011, 01:24 AM   #4 (permalink)
While Wikipedia and other reference sources are valuable, in some cases, the sheer amount of information may be overwhelming. Here's a condensed answer to your question:
The short answer is 5V. The two outer pins of the common USB port supplies the +ve and -ve 5V terminals. The two inner pins are the data lines.
A slight expansion: The current that can be drawn from a normal USB port is limited. If a connected device tries to draw too much current, the output voltage automatically drops. This prevents overloading and short-circuits. This is one reason why some USB devices like external hard disks do not function reliably with some computers.
As with many technical standards, there are variations and sub-types.
pimpom is offline   Reply With Quote
Old 19-07-2011, 01:25 AM   #5 (permalink)
tkin's Avatar
Care to elaborate on that?
Old 19-07-2011, 01:41 AM   #6 (permalink)
^Not much to elaborate. Some mobo designs limit the USB output current more severely than others. The device can't get enough juice and functions erratically or not at all. To circumvent this, some devices come with two USB connectors but stability is sometimes marginal even then.
I've observed this several times. In some cases, I confirmed the fact by measuring the output voltage at the terminals.
Old 19-07-2011, 01:43 AM   #7 (permalink)
Also happens when you cramp too many USB devices to a hub.
Old 19-07-2011, 01:47 AM   #8 (permalink)
Yep. That happens too.
