Old 18-07-2011, 09:33 AM   #1 (permalink)
ICE COOOOL!!!
IronCruz's Avatar
Default Strange problem in PC
My uncle have 3-4 year old HCL pc. Now when i turn on the UPS and press power button, the system starts but monitor light will be orange. Then i keep pressing the power button till it get off. Now again i start the system starts. Now while working suddenly system restarts. This happens everytime. What may be the problem?
AMD Athlon II X4 620,2GB DDR2 Kingston 800MHz,BIOSTAR TA790GXB A2+,Cooler Master Extreme Power Plus 450w,Zotac 9600GT 512MB,Dell Inspiron N5030,Creative EP 630,Sony Ericsson J105i Naite.
IronCruz is offline   Reply With Quote
Old 18-07-2011, 11:13 AM   #2 (permalink)
Default Re: Strange problem in PC
Try to use the system without a UPS. Also as the system is so old now, I am assuming that the UPS is as old as PC so dont stress it much. Just connect CPU to UPS so that during a powercut you can shut down the PC with the powerbutton. Atleast iw will prevent a corrupt Windows.
What is the UPS? Brand? Wattage?
Old 19-07-2011, 02:26 PM   #3 (permalink)
ICE COOOOL!!!
IronCruz's Avatar
UPS brand is supercomp, dont know wattage. I guess it's new. But there are many connections plugged into the UPS.
Old 19-07-2011, 03:04 PM   #4 (permalink)
Fullbring
Zangetsu's Avatar
IronCruz,
Try to use the PC without UPS.& observe the issue.
even if the problem of restart happens then PSU might be faulty.
