Old 17-07-2011, 05:01 PM   #1 (permalink)
Default HP ProBook 4520a shows not charging
New to this forum and first post here.
O.K. Got this notebook few days back (not even a week) and it turns out weird. Well, the problem is that when plugging the AC adapter, it shows on the battery status "96% available (plugged in, not charging) and the battery level never go beyond 96%. need help from experience/expert. I mean HP ProBook 4520s
riders4siam is offline   Reply With Quote
Old 17-07-2011, 10:50 PM   #2 (permalink)
andcha's Avatar
Default Re: HP ProBook 4520a shows not charging
Try unplugging the charger, remove the battery for a minute and then insert it again.
Worked for me, might work for you as well.
andcha is offline   Reply With Quote
Old 18-07-2011, 07:39 AM   #3 (permalink)
mithun_mrg's Avatar
Try to Calibrate ur battery
HP Battery Health Center
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 19-07-2011, 12:34 PM   #4 (permalink)
i guess this is not a problem, may be it's their technology. to my experience, the charging light goes off when the battery is fully charged and then seize charging between 95 to 100% (if attached charger when in between 95-100% of battery status). anyway, thanks for your advice
