Old 14-07-2011, 09:14 PM   #1 (permalink)
Multiplex Of Technology
TechPlex's Avatar
Default Dual Channel Vs. Single Channel
Heyo Friends! I am planning to combine the 2GB RAM of my laptop with another 2GB RAM of same brand and specifications. All because of hearing about Dual Channel Memory Architecture. I have heard that it doubles the quickness and performance of the computer. Is it true?
Technology is just like time. Never stops. Keeps changing...
TechPlex is offline   Reply With Quote
Old 14-07-2011, 10:15 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: Dual Channel Vs. Single Channel
Highly probable that the laptop takes single channel OR dual channel not both.
Yes, the throughput goes up. But not double.
asingh is offline   Reply With Quote
Old 15-07-2011, 04:07 AM   #3 (permalink)
Fast 'N' Furious
topgear's Avatar
@ OP - if you are getting 2GB more ram with current 2GB then I would suggest you to use Win 7 x64 version for improved performance
ToPsPeEeD = FaSt BuT StEaDy
Old 15-07-2011, 08:16 AM   #4 (permalink)
TechPlex's Avatar
Yes, of course! Since 4 GB is the liit in 32 Bit Win 7. Now I will have to download one.
Old 15-07-2011, 01:51 PM   #5 (permalink)
Here I Comes You Viruses
Geek-With-Lens's Avatar
Never Download Pirated Stuffs. Go OpenSource.
Back To ThinkDigit Forum After Long Break.
Razer Carcharias 8-)
Swan M10 :-D
Geek-With-Lens is offline   Reply With Quote
Old 15-07-2011, 01:51 PM   #6 (permalink)
he performance ill not improve considerably (ads in double) but you would notice increased responsiveness in lieu of larger memory. Anyway most laptops cannot fully take advantage of dual channel memory 'coz of limitations of other hardware parts such as slow HDD & onboard graphics..
Nevertheless its good to have more memory...
HailStonE is offline   Reply With Quote
Old 15-07-2011, 02:03 PM   #7 (permalink)
Fullbring
Zangetsu's Avatar
thats piracy...whatever u do pls don't mention it in TDF
Old 16-07-2011, 05:04 AM   #8 (permalink)
Fast 'N' Furious
topgear's Avatar
@ TechPlex - you better get windows 7 x64 home premium edition and the price should be around ~5.8k.
