14-07-2011, 08:25 PM
Multiplex Of Technology
Best Headphone in budget
Friends I need your help to buy a good Headphone set with durable mic. My budget is 450-600 Rupees. I need a good body too. The sound should be with bass.
Technology is just like time. Never stops. Keeps changing...
14-07-2011, 08:56 PM
Here I Comes You Viruses
Re: Best Headphone in budget
Back To ThinkDigit Forum After Long Break.
Razer Carcharias 8-)
Swan M10 :-D
14-07-2011, 09:11 PM
Sorry! I forgot to mention that I don't want those mini headsets. I will be using the unit heavily. So I need big ones.
15-07-2011, 12:25 AM
Mmmph!!!
those will be much more comfortable than ANY "big ones" at your budget.
anyway, its your ears that will take a beating, so man up and get "big ones"
Mmmphh-mphhhh-mmphh mhh!!!
Steam : doomgiver
15-07-2011, 12:39 AM
Hmmmmm
Good headset with mic at your budget- Logitech ClearChat Premium PC Headset @Rs 650/-
15-07-2011, 01:20 AM
127.0.0.1
I use iBall Rocky , they cost me Rs 325 , i'm no expert but i think you'll be impressed by them. Clear sound , definitive thump , and quite rugged.
Intel i5 760 || Gigabyte H55 || Corsair 4GB 1333MHz Value || XFX HD5670 1GB
WD 2TB Green + Seagate 5900RPM 2 TB + Seagate Freeagent 1 TB x2
Corsair CX400 || Zebronics Bijli || Samsung P2350 23.5" || Altec Lansing VS2621
My Speedtest :D
15-07-2011, 02:45 AM
iDota
I have these. They are almost dead now, within a year. There seems to a loose connection causing one of the speakers to black out quite often. The volume knob is a complete mess, touching it will cause the headphones to stop producing sound.
IMO the volume knob on the headsets shouldn't be fiddled with. Instead using the desktop controls will prolong the life. Read the same in many forums.
Apart from that, they produce good sound and are moderately confortable and good for video chatting.
15-07-2011, 02:53 AM
Hmmmmm
I am also using this till now without any problem.Logitech has also 3years replacement warranty.But Op can choose any other model as stated by mitraark if he wants
15-07-2011, 03:06 AM
Project Halcyon V2.0
Lets see if I can break the slider of my siberia, its built like a tank
Project Halcyon v2.0:
15-07-2011, 03:13 AM
Hmmmmm
Give me your tank, i will break into pcs. if you want
15-07-2011, 04:13 AM
iDota
Damn! Now where is my bill. Both my headphones are under warranty but I don't have their bills.
I have faced the same problem with many other headphones with an inbuilt volume rocker/dial. They malfunction and cause a break in connection leading to poor reception.
Either that or I am too rough in handling them.
15-07-2011, 04:21 AM
Hmmmmm
^^Yes bill is very essential for RMAed any product.
For voice and video call any headphone from brand like Logitech/Creative/Microsoft is good.
15-07-2011, 04:23 AM
iDota
Talking about these right
15-07-2011, 04:28 AM
Hmmmmm
Yes.I have this headphone.Purchased at Rs 650/-
15-07-2011, 04:38 AM
iDota
I spent Rs.885/-. You have them for 3 years?
If so OP can get them. They sound good for the price.
15-07-2011, 04:47 AM
Hmmmmm
No not three years just 8 months has passed.Till now it performs really good.
15-07-2011, 04:57 AM
iDota
Mine must be dying of misuse then. I don't remember using it much though. Do you use the volume controls of the headset?
I think he should get this then, hoping I haven't scared him away from these. They sound good and are pretty good for video conferencing. I've used it more for games and music though.
15-07-2011, 04:59 AM
Hmmmmm
Yes.Use it frequently when needed.Its good OP can buy this headset eye closed.
15-07-2011, 08:23 AM
#19 (permalink)
Listen Pals, I am miles away from video chats. Now I wanted those for Gaming, Movies and music. What say?
15-07-2011, 02:46 PM
#20 (permalink)
iDota
^That is exactly what I used mine for. But if you are looking for one without a mike then you have to look elsewhere.
