Old 13-07-2011, 03:10 PM   #1 (permalink)
Default Resulution setting for my system changes after restart !! HELP !!
I am facing a small issue wrt display resution settings...
Sapphire HD 5670 1Gb DDR5
Monitor : 17" CRT
After I installed the graphics card, whenever i restart my PC, the display resolution changes to the basic resolutin 1024 X 768. Than I have to go and manually change the setting to 1280x1024. Help.. suggest wht settings to be done?
Alive_Hunter is offline   Reply With Quote
Old 13-07-2011, 05:12 PM   #2 (permalink)
Adam young
sukesh1090's Avatar
Default Re: Resulution setting for my system changes after restart !! HELP !!
Are you sure that your monitor supports that resolution?
:razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
sukesh1090 is offline   Reply With Quote
Old 13-07-2011, 05:40 PM   #3 (permalink)
mithun_mrg's Avatar
i would guess ur 17" Crt native resolution is 1024X768 thats why it is happening try changing the refresh rate to 60 HZ along with the resolution & see if the problem persists
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 14-07-2011, 06:26 PM   #4 (permalink)
Are you using Linux??
HellKing is offline   Reply With Quote
