Old 12-07-2011, 04:28 PM   #1 (permalink)
Daniel Prince
Prince Sinha's Avatar
Default Got blue screen alonwith a lot of problem
Hey guys,
I am in great trouble. I bought a new PC and from the beggining I have encountered BSOD alongwith a lot of problems. I am using Vista. I had the same problem when I used XP , So , I thought to switch to Vista but still no solution! I tried differend windows but problem do not go away. The same window work fine on my friends PC.
Sometime super fetch stop working, Windows restore do not respond. While installing those games which I used to play on my outdated PC says "CRC error" I have to play SOF2 by copying the installed game from my friend's PC. The games which runs fine with 1Gb Ram doesnt seem to work with mine with 2Gb Ram.
Everytime the Blue Screen code is different.
The following are the data of BSOD which I encountered 1 after other:-
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.0.6000.2.0.0.768.3
Locale ID: 1033
Additional information about the problem:
BCCode: 1000007e
BCP1: C0000005
BCP2: 818E182C
BCP3: 875C9068
BCP4: 875C8D64
OS Version: 6_0_6000
Service Pack: 0_0
Product: 768_1
Files that help describe the problem:
C:\Windows\Minidump\Mini042711-02.dmp
C:\Users\Daniel Prince\AppData\Local\Temp\WER-28328-0.sysdata.xml
C:\Users\Daniel Prince\AppData\Local\Temp\WER7F71.tmp.version.txt
Problem signature:
Locale ID: 1033
BCCode: 10000050
BCP1: FD80BA88
BCP2: 00000000
BCP3: 820E17C7
BCP4: 00000000
Problem signature:
Locale ID: 1033
BCCode:4e
BCP1: 00000002
BCP2: 0001E92B
BCP3: 0007F69F
BCP4: 00000001
Service Pack: 0_0
Product: 768_1
Problem signature:
Locale ID: 1033
BCCode:10000001
BCP1: 91A6C678
BCP2: 00000000
BCP3: FFFF0000
BCP4: 00000000
Service Pack: 0_0
Product: 768_1
Problem signature:
Locale ID: 1033
BCCode: 1000008e
BCP1: C000001D
BCP2: 820421FA
BCP3: A4516CD0
BCP4: 00000000
Service Pack: 0_0
Product: 768_1
I hope you can help me! Thanks!
And not only this while formatting windows also I get BSOD. I am pissed guys plz help me. I have got antivirus on my computer to make sure that there is no viruses or worm or Trojans.
Prince Sinha is offline   Reply With Quote
Old 12-07-2011, 07:35 PM   #2 (permalink)
Electronic.
Neuron's Avatar
Default Re: Got blue screen alonwith a lot of problem
CRC errors usually arise due to the presence bad sectors on the hard disk.It can also cause BSODs.I suggest you get a new hard drive and see if any BSODs or CRC errors occur.
I don't always make sense,but when I do,I don't.
Neuron is offline   Reply With Quote
Old 12-07-2011, 10:16 PM   #3 (permalink)
Daniel Prince
Wink Re: Got blue screen alonwith a lot of problem
Thanks buddy. I had doubt about it. I really appreciate your help. Thanks!!!!!!!
