Old 11-07-2011, 03:16 PM   #1 (permalink)
Default graphics card for laptop
guys,I have a hp pavillion dv4 1211-tu notebook and it has a pci express card slot available.Does that mean that i can add an externel gfx card?if so which things r needed and what r their latest price in kolkata?btw my mobo is hp 30f7 if that matters.
satsworld is offline   Reply With Quote
Old 11-07-2011, 03:57 PM   #2 (permalink)
Adam young
sukesh1090's Avatar
Default Re: graphics card for laptop
thisHP Pavilion dv4-1211tu Laptop- Price,Specs website states that your notebook have the express card slot and so it can be used as a pcie slot but i don't think that you can insert a desktop graphics card in that,and about laptop graphics card you can look at this article
Notebook Video Graphics Card Guide
:razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
sukesh1090 is offline   Reply With Quote
Old 11-07-2011, 03:58 PM   #3 (permalink)
Nopes it DOESNT mean it will be possible to add a external gfx card.
Adding a GPU to a laptop isnt simple and is next to impossible. So its always better to have a good GPU when you buy it.
Still, have a look at this- Upgrading Your Laptop's Graphics Card | PCWorld
Dont blame me or any other member of the forum if you mess up anything
Old 12-07-2011, 11:42 AM   #4 (permalink)
Cool Re: graphics card for laptop
If it was not possible then giving a pci-e slot was worthless.Companies like HP certainly will not play with their products & customers.I am not going to change my onboard graphics card.I want to have an external one to have better 3d experience.
Old 12-07-2011, 12:15 PM   #5 (permalink)
Laptops don't have a "PCI express slot". Kindly verify what you are saying.
Old 13-07-2011, 08:32 AM   #6 (permalink)
OK ico.Then plese make me understand what is the work of the express card slot in a laptop.go here HP Pavilion dv4-1211tu Laptop- Price,Specs
Old 13-07-2011, 12:58 PM   #7 (permalink)
Adam young
sukesh1090's Avatar
may be he is talking about express card slot.i think i read in Wikipedia that it can be used as pcie slot but i am not sure about that and satsworld,i suggest you not to do anything with your laptop.if you want to game then better go with desktop.
-Rifleman's Creed
Old 13-07-2011, 02:45 PM   #8 (permalink)
Express card slot is for things like TV tuner, 3G modems, card readers etc. You will rarely, infact, you will not find any GPU for it.
And even if you find one (which you won't), it will be bandwidth starved and not at all perform good. In a nutshell, not worth at all. When you buy a laptop, the only things which you can easily upgrade are RAM and Hard disk.
Old 13-07-2011, 05:12 PM   #9 (permalink)
Adam young
sukesh1090's Avatar
oh,thanks brother.
-Rifleman's Creed
Old 14-07-2011, 09:07 AM   #10 (permalink)
Yes,thanks ico.It helped a lot.
