Old 10-07-2011, 11:43 AM   #1 (permalink)
Default 'USB device not recognized' error for pen drive
I have a transcend 2 GB pen drive thats giving 'USB device not recognized' error in all the systems its been inserted. Actually it started to give the error and then automatically started working at first.Now its not working at all.Any solutions?
ra_sriniketan is offline   Reply With Quote
Old 10-07-2011, 12:44 PM   #2 (permalink)
Default Re: 'USB device not recognized' error for pen drive
Have you tried all the USB ports on your computer, including the rear ones? If you've done that and the result is the same, the next thing to do is to insert another pendrive into your computer.
Another thing you can do is to insert the pen drive into another computer and see if it's recognized there.
pimpom is offline   Reply With Quote
Old 10-07-2011, 12:48 PM   #3 (permalink)
Try the tips and trciks mentioned here-
USB device is not recognized when you attach it immediately after your Windows XP-based computer resumes from standby or hibernation
Old 10-07-2011, 02:51 PM   #4 (permalink)
127.0.0.1
mitraark's Avatar
USually this happens when Pen Drives 'die'/ I accidentally flushed my 2 GB Transcend ,forgot to take it out of the pocket and washed the pants It worked that day , gave error 2days after that .
Intel i5 760 || Gigabyte H55 || Corsair 4GB 1333MHz Value || XFX HD5670 1GB
WD 2TB Green + Seagate 5900RPM 2 TB + Seagate Freeagent 1 TB x2
Corsair CX400 || Zebronics Bijli || Samsung P2350 23.5" || Altec Lansing VS2621
My Speedtest :D
mitraark is offline   Reply With Quote
Old 10-07-2011, 05:25 PM   #5 (permalink)
Its happening in all machines.
Old 10-07-2011, 05:58 PM   #6 (permalink)
In that case, you have to accept that its life is over. One last thing you can try is to put your pen drive in the sun for a couple of hours. This is to get rid of any moisture that might have accumulated inside. Place it with the contact side pointing upwards. It's a long shot, but it's worth a try as a last-ditch measure.
Old 10-07-2011, 09:47 PM   #7 (permalink)
Cool Buddy's Avatar
Most pen drives have a pretty long warranty, you could try to get a replacement. For transcend, you will most probable need the original invoice. You could go to the shop you bought it from, if you have the bill
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 10-07-2011, 10:07 PM   #8 (permalink)
Stuck in Time...
Vyom's Avatar
@pimpom: That's a good suggestion. I will try it if I accidentally wash one of my drives
Btw, agree with Cool Buddy, OP can ask for replacement, if it doesn't seem physically damaged.
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is offline   Reply With Quote
Old 10-07-2011, 10:34 PM   #9 (permalink)
Some readers may think that my suggestion was made out of some wild guesswork, but it's based on sound technical principles and my own experiences (I'm in electronics).
For many/most of us in India, our technological marvels are exposed to a lot of dust and pollution, with a bonus of high atmospheric moisture levels in the rainy season. The moisture clings to the accumulated dust and pollution particles long after the air is reasonably dry again. This plays havoc with sensitive electronic circuits.
Sometimes, the dust-moisture combination is lodged so firmly that they don't dry out even after exposing them to the sun. Sometimes the tiny spaces between circuit elements are bridged by corrosion products, causing short-circuits. In such cases, if the product is valuable, the only thing to do is to clean everything thoroughly. But this is a job for experienced people only.
Old 11-07-2011, 06:55 AM   #10 (permalink)
Cool Buddy's Avatar
Unless any device is powered on while wet, the chances of getting damaged due to the water are low. That's why it is advised to remove the battery immediately if a cell phone gets wet. I have myself put the pen drive in washing machine twice. Just let it dry thoroughly before using it and you should be fine
Nokia 5230 :(
Old 11-07-2011, 11:07 AM   #11 (permalink)
127.0.0.1
mitraark's Avatar
I'v heard of a solution for removing moisture in case you get the thing wet.. Dip the thing completely in Alcohol , then dry it. Alcohol , easily vaporises. Actually , it was the solution for "WHat to do if you drop your laptop in water" Anyways , it probably does work , but the site already had the warning , "Try it only if you are a fearless *******." .. so that's that.
My Speedtest :D
Old 11-07-2011, 11:45 AM   #12 (permalink)
I use various types of alcohol and other chemicals extensively in my work in electronics and computers. They are very useful if you know what you're doing. However, blindly advising others to use them as a general cure-all can be misleading and could do more harm than good.
For example, organic solvents, including alcohol, can dissolve some plastics, seals and lubricants. Moreover, many such chemicals mix readily with water and often have a high content of water by absorbing moisture from the air. Even if the chemical itself evaporates quickly, the water is left behind and that can cause more problems.
