Originally Posted by mithun_mrg
See i have opened WD&Seagate External drives 160GB&250GB resp. both of them had normal SATA connections i.e i was able to connect them to the desktop with the sata power & data cable there is one more catch does ur laptop use the normal sata connector or a modified one i dont think it is worth taking a risk for 3K bucks
u should get a new drive form the manufacturer also i think if u open the Casing of the EXT. HDD warranty will void
Hi Mithun...
THanks for the reply. Just wanted to know, you opened 2.5" External drive or 3.5" ones, like the ones in out Desktops?
And I am aware of warranty issue. But this is a part of experimentation, and I have not encountered any harddisk failures till now, so not much worried about the same.
To be frank, Cost is also not the issue. Its the excitement of tearing a new hardware and still make it work, that counts..
Dear Suyash_123...
Thanks for putting remark in a jiffy....
If you have read my nick name, you would not have called me "new to Computer h/w things and want to experiment" or u haven't heard the term "Modder".
I have been messing with computers both soft side and hard side when 386 pcs were the rage. I was lucky to have one at that time.
Then I assembled my Celeron, from scratch.(Many Thanks to Digit, then CHip). Then I started experimenting on a Pentium 1 lying idle at office. I repaired many pcs of my friends in College, mostly Pentium 3 or Celeron.
Then I Assembled my current system, AMD athlon x2, under Rs. 12,000(4 years back.) Still working like tick tick. People drop their jaws when they see my wire clutter less system from the Fibre side panel, lit with LEDS for clearer view.
My Lenovo laptop is also not spared!
And you also got the question wrong. I am not wanting to open HARDDISK, but CASE that holds 2.5" harddisk.
Just making myself clear. No intention to disrespect you.
