Old 10-07-2011, 12:09 AM   #1 (permalink)
SWAT 4 GameR
ashis_lakra's Avatar
Question Northbridge affects GPU ?
Hi,
I was wondering of my unplayable and inconsistent frame rates on my computer. I had a discussion with a member and he said the ICH07 southbridge is limiting the communication from CPU to GPU and vice versa ..
Is this true ? shall i go for mobo with ICH10 to increase performance ?
Corei5 2500K@ 3.3 GHZ ASUS P8-H61-M 8GB DDR3 XMS3 1.5 TB HD BenQ GL2450 24"
MSI N560 GTX Ti TF II Razer Deathadder 3500 Cooler Master Elite 430 Logitech K260 (WL) Seasonic S12 II 620W
ashis_lakra is offline   Reply With Quote
Old 10-07-2011, 01:19 AM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: Northbridge affects GPU ?
The BUS lines between the north bridge host controller and PCI.E lanes is the MCH, which is the G31. The ICH07 southbridge controller is for low level connectivity. HDD/USB/other communication channels. So changing south bridge will not affect your performance ratios.
asingh is offline   Reply With Quote
