09-07-2011, 12:44 PM
PSU, PC fan starts halfway,stops.System doesn't boot.
Hey guys, today morning, my PC wasn't booting up.
So I opened the side to see the insides, and when I try to boot it,
PSU fan, processor fan, cooling fans start halfway, rotate for a while and then again stop. This on and off pattern keeps on happening. It just doesn't boot up  . I'm assuming the fault is with my PSU...
What do you guys have to say? Can internal wires be loosely connected or something?
Thanks in advance.
09-07-2011, 01:48 PM
Re: PSU, PC fan starts halfway,stops.System doesn't boot.
Reconnect the wires of the mobo. Especially the one from motherboard to CPU fan. The fan might be dead as well. Get a new fan and some thermal paste and them try.
Yes the PSU might be dead as well
This happened today morning only
09-07-2011, 02:52 PM
I really don't think the fan is dead as ALL the fans connected to the PC go in a on-off loop in similar manner (cooling,processor,psu, even GPU fan!, which I just noticed.)
I think the fault is with PSU then. But thing is, I can't source a PSU. THOUGH, I have an old PC with 350W IIRC, would that be enough for just major components? like I'll remove RAM, GPU etc.
I'll try reconnecting the wires.Thing is, I haven't before fiddled with the interior of my PC, mostly just cleaning and RAM removal, nothing more.
09-07-2011, 02:59 PM
Then ask a local PC guy how much he will charge for refitting wires.
The problem seems strange. and as you said evrything else works fine I still believe the CPU fan might be acting funny
09-07-2011, 03:20 PM
Can I learn it online or something? Because this one guy I know, he takes ages to come. He'll probably come on Tuesday If I ask him today.And I'm free the whole day today.I'm using my spare super slow PC atm.
So, you got any link or something? I don't think it would take more than 3-4 hours, would it?
09-07-2011, 03:28 PM
The Assassin
Please post your system configuration as that might help pinpoint if it is a PSU problem.
09-07-2011, 03:32 PM
My config is
Abit Ip35-e
Intel E8400 (stock clockspeed, not overclocked or anything.)
Transcend 2GB RAM
Seagate 640GB
VIP 500W PSU2.6k
dell se198wfp
Palit H4850
09-07-2011, 04:53 PM
Originally Posted by siddhesh222
My config is
Abit Ip35-e
Transcend 2GB RAM
Seagate 640GB
VIP 500W PSU2.6k
dell se198wfp
Palit H4850
I dont think ur PSU is enough for the GPU i think the GPU has blown ur PSU also dont risk ur 350W psu in this system
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
09-07-2011, 05:18 PM
Testing without your graphics card and the HDD is a good way to find out what's wrong. But since your motherboard doesn't have an onboard gfx, you'll have to fit at least a low-end gfx card. If you have a spare one or can borrow one, go ahead.
A good 350W PSU is more than good enough for use without a power-guzzling card like a 4850.
It's not difficult, but before doing anything, make sure you discharge yourself of any static electricity by touching a grounded object like a metal water pipe first. And also disconnect everything from the AC mains.
09-07-2011, 05:47 PM
Ah then I guess I'll have to leave it to some professional, none of my friends parents would let me borrow their gfx ( we're 16 yr old kids lol), not like I even have the slightest idea how would I fit it properly etc.
Well I think 500W must be enough for this, It's been running since the last 3-4 years without any problem...
09-07-2011, 06:23 PM
U r right bro take it to the service center it is a genuine hardware fault 500W is enough for ur card if it is i think ur PSU is overated which is normally done in cheap/indian branded PSU's
