Old 08-07-2011, 05:39 PM   #1 (permalink)
SWAT 4 GameR
ashis_lakra's Avatar
Red face How to check compatible OS with my CPU ?
Hi,
I have just bought 2x2GB Corsair XMS2 800 MHZ RAM, and want to upgrade my Windows 7 64 bit to fully utilize the 4GB RAM..
Is my processor compatible with 64 bit OS ? Is there any tool to check the architecture of my processor like 32 bit or 64 bit?
Corei5 2500K@ 3.3 GHZ ASUS P8-H61-M 8GB DDR3 XMS3 1.5 TB HD BenQ GL2450 24"
MSI N560 GTX Ti TF II Razer Deathadder 3500 Cooler Master Elite 430 Logitech K260 (WL) Seasonic S12 II 620W
ashis_lakra is offline
Old 08-07-2011, 05:55 PM   #2 (permalink)
Manchester United <3
Ishu Gupta's Avatar
Default Re: How to check compatible OS with my CPU ?
Intel® Core™2 Duo Processor E7200 (3M Cache, 2.53 GHz, 1066 MHz FSB)with SPEC Code(s)SLAPC, SLAVN
Yes it does.
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
Ishu Gupta is offline
Old 08-07-2011, 06:02 PM   #3 (permalink)
Excessive happiness
furious_gamer's Avatar
@OP
Your avatar suits you.
Just go to Intel's site and check for yourself.
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
furious_gamer is offline
Old 08-07-2011, 07:04 PM   #4 (permalink)
Cick here..!!
ico is offline
