Old 08-07-2011, 04:10 PM   #1 (permalink)
Adam young
sukesh1090's Avatar
Default system crash problem
guys my system crashed thrice today while playing songs.it just gives BSOD.when i checked the event viewer it just mention something about kernel memory.
here is the analysis of my bsod by a website
Configuration - - Ma-Config.com
and here is pic of event viewer
:razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
sukesh1090 is offline   Reply With Quote
Old 08-07-2011, 05:05 PM   #2 (permalink)
mithun_mrg's Avatar
Default Re: system crash problem
Maybe sone security programs running in background is causing the crash what security software/AV ur using
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 08-07-2011, 05:34 PM   #3 (permalink)
Adam young
sukesh1090's Avatar
^^Thank you buddy.
@mithun_mrg
my AV is avast and i am using it from 1 year and there was no problem so i think its not the culprit.
-Rifleman's Creed
Old 08-07-2011, 07:24 PM   #4 (permalink)
mithun_mrg's Avatar
try disabling it then run the music player & get back
Old 09-07-2011, 05:37 AM   #5 (permalink)
Fast 'N' Furious
topgear's Avatar
Av updates itself from time to time and with some update the AV engine, guard got updated too and if they have some stability issue that can make the whole system unstable - so update the av first and try what mithun has told.
BTW, if possible check your HDD with HDTune and memory with Memtest86+
ToPsPeEeD = FaSt BuT StEaDy
Old 09-07-2011, 11:03 AM   #6 (permalink)
Adam young
sukesh1090's Avatar
i tested RAM and HDD with those programs and no errors. i don't know what to do with Avast,i am using this program version from two months and i just updated only the virus definition and nothing else.i re installed the sound driver,now i will check the system and i will get back.
thank you.
OK guys today i played some 6-7 songs without any problem.so till now no crash if any thing happens later i will inform.thanks for the support.
-Rifleman's Creed
Old 10-07-2011, 03:08 AM   #7 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ Have you performed any windows automatic update before the crash - what app you have used to listen songs - WMP - it has it own issues
For music listening you better try KMPlayer/GOMPlayer/foobar2000 or something else
Old 10-07-2011, 02:33 PM   #8 (permalink)
Adam young
sukesh1090's Avatar
i use vlc,k-lite,xion and i didn't performed any update.and now it is working correctly.thank you.
-Rifleman's Creed
Old 11-07-2011, 03:52 AM   #9 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ ok - thanks for the info and really glad to know your system is running crash free and you are enjoying your misic collection
