Old 07-07-2011, 10:48 PM   #1 (permalink)
Exclamation Harddisk error
harddisk is not booting.if i try ubuntu it shows this error:
DBus error org.gtk.Private.RemoteVolumeMonitor.Failed: An operation is already pending.
if i use gparted to check the partition for errors it shows the following:
GParted 0.7.0 --enable-libparted-dmraid
Libparted 2.3
Check and repair file system (ext4) on /dev/sdd4 00:00:00 ( ERROR )
calibrate /dev/sdd4 00:00:00 ( ERROR )
libparted messages ( INFO )
Could not stat device /dev/sdd - No such file or directory.
Check and repair file system (ntfs) on /dev/sdd3
windows does not detect the harddisk.
any suggestions??
My Harddisk is Seagate Barracuda 7200.12 SATA.
anagh.k1 is offline   Reply With Quote
Old 08-07-2011, 09:03 AM   #2 (permalink)
mithun_mrg's Avatar
Default Re: Harddisk error
Is the HDD detected in BIOS
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 08-07-2011, 03:25 PM   #3 (permalink)
no the harddisk is not detected in bios. ubuntu detects it but it cannot read or mount it.
Old 08-07-2011, 04:49 PM   #4 (permalink)
mithun_mrg's Avatar
r u sure?? if it is not detected in Bios then how come ubuntu detects it anyway check it in another pc
also try the HDD diag. tools of UBCD if possible
Ultimate Boot CD - Overview
Old 09-07-2011, 05:45 AM   #5 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ yep, you're right - if bios can't detect a HDD in a particular rig no OS in the world can detect the HDD on the same system - so he better use some system diag tools first.
ToPsPeEeD = FaSt BuT StEaDy
