Old 06-07-2011, 08:18 PM   #1 (permalink)
Default 5.1 Speakers under 8K
Please suggest me a good 5.1 speaker system under 8K... I will be using it for watching movies..
http://mobiveda.com
vineetrocks2005 is offline   Reply With Quote
Old 06-07-2011, 09:39 PM   #2 (permalink)
avichandana20000's Avatar
Default Re: 5.1 Speakers under 8K
LOGITECH Z506 around 5200/-
NZXT PHANTOM WHITE|GA990XA UD3|955BE 3.6(O.C.ed)|MX-2|HYPER EVO|SAPPHIRE 6670 DDR5|DELL SP2309W|CORSAIR XMS 2X2GB 1333|450VX|SEAGATE 1TB|LOGITECH G110|APC 650 VA|
avichandana20000 is offline   Reply With Quote
Old 07-07-2011, 10:23 AM   #3 (permalink)
What abt Creative T6100 or T6200
http://mobiveda.com
Old 07-07-2011, 10:33 AM   #4 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Havn't heard good words (feedback) about 6-8k range 5.1 setups.
comp@ddict is offline   Reply With Quote
Old 07-07-2011, 10:41 AM   #5 (permalink)
Ok I increase my budget to 10K, can you suggest a good 5.1 speaker set now!
http://mobiveda.com
Old 07-07-2011, 10:50 AM   #6 (permalink)
mithun_mrg's Avatar
Altec Lansing 5.1 Speaker System Model No: FX5051 approx 9.5K
Altec Lansing VS3251 approx 5.5K(not sure will be available now i purchased it in 2009)
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 07-07-2011, 11:01 AM   #7 (permalink)
I think they both are discontinued because they are not available on the official website of Altec Lansing
http://mobiveda.com
Old 07-07-2011, 11:09 AM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Z506 is a decent model. also check Edifier DA5000 if you can up your budget to 10k and check F&D D6000 which should be inside your budget.
desiibond is offline   Reply With Quote
Old 07-07-2011, 11:23 AM   #9 (permalink)
Just wanted to know does z506 supports pure 5.1 or will it split the sound between 5 speakers ?
http://mobiveda.com
Old 12-07-2011, 02:53 PM   #10 (permalink)
Techno Freak
Just check Logitech but i also don't like logitech - Z506 because of few thing like.
The Volume control is on speaker and no remote (wire or wireless).
(as it is 5.1 speakers Must be arrange properly and at proper distance from listener , and thus front speaker must be somewhat away from user in front direction but as volume control is in front speaker you have to go near to speaker every time to control volume )
also bass control is at back of Woofer (are you Kidding me????S#$t will u go everytime to subwoffer to raise or decrese the bass????)
It is Not wall mountable, comes very imp thing when room is very small or very large .
but one good thing is the RMS and wattage of Speaker is Fine...
i will say u to check out for
Altec Lansing 5.1 Speaker: FX5051
Altec Lansing VS3251 - 5.5K
suyash_123 is offline   Reply With Quote
