Old 06-07-2011, 12:16 PM   #1 (permalink)
Smile How to connect PC and laptop through LAN...
I have a PC running windows XP and I recently bought a Dell XPS 15 running windows 7 home premium.I want to copy some data from my PC to my laptop.How can I do it through a LAN wire?Is there any other way?
harpreet115 is offline   Reply With Quote
Old 06-07-2011, 12:33 PM   #2 (permalink)
Project Halcyon V2.0
tkin's Avatar
Default Re: How to connect PC and laptop through LAN...
Well, you can buy an amkette usb connecting cable, or just connect the two pc by lan, make sure they are part of the same workgroup, also you may need to manually configure their ip addresses so they do not conflict.
Project Halcyon v2.0:
[i7 2600k|Asus Z68 VPro|Vengeance 2x4GB|MSI GTX580 Lightning]
[TX 750v2|Seagate 500GB+WD Cav Black 1TB|CM HAF 912 Adv]
[Logitech G110|G500|Adata/750GB+WD/500GB USB 3.0]
[APC 1100VA|XBox 360 Controller|Noctua U12PSE2]
[Siberia Soundcard(Xear 3D)|Koss Portapro|FiiO E6]
[Audio Technica M35|PL30/EOL'ed]
tkin is offline   Reply With Quote
Old 06-07-2011, 04:50 PM   #3 (permalink)
mithun_mrg's Avatar
Just for copying data i think its better to use a pen drive or Ext HDD or a usb cable as suggested by tkin
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 06-07-2011, 07:42 PM   #4 (permalink)
saswat23's Avatar
But speeds will be better in LAN and it will also help the OP to play MP Games if he wants..
i5-2400 | P8H67M-EVO | DRW 24B3ST | WDC Blue 500GB | VENGEANCE 4GB DDR3 | FSP SAGA-II 500W | Zebronics Aviator | DELL IN2020M | MS Wired 500 Combo | Creative A-35 | iBall Rocky Headset
saswat23 is offline   Reply With Quote
Old 06-07-2011, 09:55 PM   #5 (permalink)
Cool Buddy's Avatar
see if this helps Share Files and Printers between Windows 7 and XP - How-To Geek
Nokia 5230 :(
Canon IXUS 115 HS :)
