Old 06-07-2011, 11:23 AM   #1 (permalink)
mithun_mrg's Avatar
Default List of Freewares & utilities for PC Troubleshooting/Repair
List of Freewares and Utilities
UBCD:Ultimate BOOT cd for testing Diagnosis
Ultimate Boot CD - Overview
Nlite :-For Intregrating Sata/ACHI drivers
nLite - Deployment Tool for the bootable Unattended Windows installation
Real Temp:For temperature Monitoring
Real Temp - CPU temperature monitoring
Cpuz:-For Hardware config Details
CPUID - System & hardware benchmark, monitoring, reporting
Gpuz:-For Discrete GPU monitoring
GPU-Z Video card GPU Information Utility
Wprime-For System Stability testing
Measure Computer Performance | wPrime Multithreaded Benchmark
Furmark:For vga testing
FurMark: VGA Stress Test, Graphics Card and GPU Stability Test, Burn-in Test, OpenGL Benchmark and GPU Temperature | oZone3D.Net
For Drivers
Intel :
http://downloadcenter.intel.com/
ATI/AMD:
AMD.com | Support & Downloads
VIA:
VIA Drivers Download - VIA Technologies, Inc.
SIS:
SiS - Welcom to Silicon Integrated Systems Corporation.
Please post ur Suggesions Will be continued.....
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is online now   Reply With Quote
Old 06-07-2011, 11:26 AM   #2 (permalink)
Default Re: List of Freewares & utilities for PC Troubleshooting/Repair
Real Temp wont work in AMD systems
Suggest OPEN HARDWARE MONITOR
Open Hardware Monitor - CPU Temperature, Fan Speed and Voltages in a Free Software Gadget
thetechfreak is online now   Reply With Quote
Old 06-07-2011, 12:04 PM   #3 (permalink)
Project Halcyon V2.0
tkin's Avatar
I'll add these:
HD Tune website
Process Explorer
MSI Afterburner
Project Halcyon v2.0:
[i7 2600k|Asus Z68 VPro|Vengeance 2x4GB|MSI GTX580 Lightning]
[TX 750v2|Seagate 500GB+WD Cav Black 1TB|CM HAF 912 Adv]
[Logitech G110|G500|Adata/750GB+WD/500GB USB 3.0]
[APC 1100VA|XBox 360 Controller|Noctua U12PSE2]
[Siberia Soundcard(Xear 3D)|Koss Portapro|FiiO E6]
[Audio Technica M35|PL30/EOL'ed]
tkin is offline   Reply With Quote
Old 06-07-2011, 02:25 PM   #4 (permalink)
for troubleshooting the best utility i know is ThinkDigit Forum. 100% success always.
if someone wants to have a simple but detailed view of whats installed (or want to share here directly) nothing beats this: speccy
Sam is offline   Reply With Quote
Old 06-07-2011, 09:59 PM   #5 (permalink)
Cool Buddy's Avatar
SIW shows much more information than Speccy. But that's the problem, there is too much info. So if you are looking for the basics, speccy is enough. For more detailed info SIW can be used. Keep in mind though that unlike Speccy, SIW doesn't update the result in real time, once it gathers info at startup, that remains unless you refresh.
Prio is also a good software if you are on Win XP
Nokia 5230 :(
Canon IXUS 115 HS :)
- by c4u
