Old 05-07-2011, 10:16 AM   #1 (permalink)
Default Connecting Laptop to 5.1 Speaker, Soundcard Query
Hi...
I want to connect my laptop to my 5.1 speaker system. For that I have shortlisted creative Sound Blaster X-Fi Surround 5.1 as my external sound card. Is it good ? or should I go with anything else ?
http://mobiveda.com
vineetrocks2005 is offline   Reply With Quote
Old 05-07-2011, 11:45 PM   #2 (permalink)
atulhost's Avatar
Default Re: Connecting Laptop to 5.1 Speaker, Soundcard Query
Creative Sound systems are very reputed fantastic, I have heard the sound of 2.0 and felt it very good. As yours would be 5.1 its just more than enough from my point of view. If you can extend your budget more then only I would suggest you to check of JBL as a option.
Host.co.in - Web Hosting India
atulhost is offline   Reply With Quote
- by c4u
