Old 05-07-2011, 03:26 AM   #1 (permalink)
Question Suggestions needed for CPU/Mobo/RAM combo
I just signed up after googling for hours trying to come up with a mobo/cpu/ram combo i will be buying tomorrow. I fried my RAM/CPU today with an ESD donno which one went..but the mobo was an old one. So after pondering over the internet I have come up with this:
CPU: i5-2500k
RAM: 4Gb Corsair Vengeance DDR3
Mobo: Asus P8P67 or Z68.
Parts I will reuse:
HDD: 80, 500, 1000 GBs HDDs all Seagate
GPU: ATI 5770 HD
Cabinet (iBall)
PSU: CoolerMaster 600W
As I mentioned I own an old Ati HD 5770, will sell it some time..so trying for a future proof solution with the GPU (will go dual gpu CroosfireX) anyway.. what tweaking might you all suggest.
I am open to suggestions.
Thanks
obhi is offline   Reply With Quote
Old 05-07-2011, 11:06 AM   #2 (permalink)
Default Re: Suggestions needed for CPU/Mobo/RAM combo
Originally Posted by obhi
CPU: i5-2500k
Great choice and combo. If you can extend budget by 6k you can also get i7 2600k
thetechfreak is online now   Reply With Quote
Old 05-07-2011, 12:21 PM   #3 (permalink)
Los7 Cau53
eagle06's Avatar
I think you should change the PSU too?
i5 2500k @3.3 stock cooler | GA-P67A-UD3-B3 | Sparkle GTX560 Ti 1GB | CMX4GX3M1A1600C9 | Benq HD2222HDL | Antec High Current Gamer 620W | CM Elite 430 Black | Microtech 800 VA | VS4621 :-x |MX518 |
eagle06 is offline   Reply With Quote
Old 05-07-2011, 08:31 PM   #4 (permalink)
Got my thingy..and couldnt sleep for two days straight (after burning my CPU/mobo/Ram to hell)..i hate when i dont get sleep...anyway here is my rig:
z68, i5 2500K, Vengeance Corsair 4GB.
All under 31K, I bought a few more things (Wireless Keybd + mouse, TV tuner, HDMI cable, SATA connectors, et. al.)..I think they slightly overpriced me because I have never really bargained well ever.
I already own a good PSU: CoolerMaster 600W, so not planning to upgrade until I upgrade my GPUs
Old 05-07-2011, 09:23 PM   #5 (permalink)
Project Halcyon V2.0
tkin's Avatar
Nice, is the Z68 from asus? If so you might want to be careful with the TPU switch unless you have a good cpu cooler.
Project Halcyon v2.0:
[i7 2600k|Asus Z68 VPro|Vengeance 2x4GB|MSI GTX580 Lightning]
[TX 750v2|Seagate 500GB+WD Cav Black 1TB|CM HAF 912 Adv]
[Logitech G110|G500|Adata/750GB+WD/500GB USB 3.0]
[APC 1100VA|XBox 360 Controller|Noctua U12PSE2]
[Siberia Soundcard(Xear 3D)|Koss Portapro|FiiO E6]
[Audio Technica M35|PL30/EOL'ed]
tkin is offline   Reply With Quote
Old 05-07-2011, 10:08 PM   #6 (permalink)
Yea, P8z68-V-Pro, I am not going to touch overclocking really unless I am stress testing...any issues with the TPU switch and cooler if I leave it at defaut settings..so i should be careful about turning it on until i get some cooling rig??
Old 05-07-2011, 11:08 PM   #7 (permalink)
tkin's Avatar
No no, switch is absolutely fine, if you use TPU it will auto oc your cpu, stock cooler can not handle the oc, so it will overheat, so do not oc it like that, get a good cooler and oc it manually, tpu is for noobs and not the best way to oc.
- by c4u
