Old 01-07-2011, 09:21 PM   #1 (permalink)
Default BSOD
hey guys i m having problem with my comp
sometimes all of sudden my comp crashes.
after that pc reboots fine. below is description of the problem plz help
my OS WIN 7 Ultimate bit
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1033
Additional information about the problem:
BCCode: 3b
BCP1: 00000000C0000005
BCP2: FFFFF88005127817
BCP3: FFFFF88006E378A0
BCP4: 0000000000000000
OS Version: 6_1_7600
Service Pack: 0_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\070111-12854-01.dmp
C:\Users\admin\AppData\Local\Temp\WER-37409-0.sysdata.xml
pritamk is offline   Reply With Quote
Old 01-07-2011, 10:13 PM   #2 (permalink)
MegaMind's Avatar
Default Re: BSOD
^^Full pc spec pls...
R u using a AMD GPU?
i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - 1TB 7200.12 - 9800GT - CM M600 - NZXT Gamma - XONAR DX + VS4121/XB500 - OptX AW2210
MegaMind is offline   Reply With Quote
Old 01-07-2011, 10:44 PM   #3 (permalink)
Default Re: BSOD
yes
intel i5 2500
INTEl DH67BL mobo
ATI 1 GB 6950
4 GB RAM
Old 01-07-2011, 10:53 PM   #4 (permalink)
MegaMind's Avatar
Default Re: BSOD
PSU?
Do u hav Afterburner installed?
Old 01-07-2011, 10:57 PM   #5 (permalink)
Default Re: BSOD
PSU corsair 550 WAtt
pardon my ignorance but i have no idea what afterburner is. And i havnt installed it myself if its already installed then i dont know it
i tried to check for solution it said ATI graphic driver stopped working
Old 01-07-2011, 10:58 PM   #6 (permalink)
MegaMind's Avatar
Default Re: BSOD
^^Update the GPU drivers...
MSI afterburner is a GPU OCing utility..
Did u use any other GPU before installing 6950?
Old 01-07-2011, 11:45 PM   #7 (permalink)
Default Re: BSOD
no its first time i bought a desktop
will msi afterburner work for ATI 6950?
Old 01-07-2011, 11:50 PM   #8 (permalink)
MegaMind's Avatar
Default Re: BSOD
Wil work for any gpu...
BTW, which catalyst version r u using?
Old 02-07-2011, 12:00 AM   #9 (permalink)
Default Re: BSOD
currently i have 10.12
i have downloaded updated version need to install it
Old 02-07-2011, 12:07 AM   #10 (permalink)
MegaMind's Avatar
Default Re: BSOD
The BSOD u get is due to graphics issue...
This should help,
1. remove the GPU
2. boot thro. onboard vga
3. remove the Catalyst drivers, download this
4. pow. off
5. insert GPU, pow. ON
6. install the dwnlded driver
Hope this helps....
- by c4u
