Old 30-06-2011, 08:21 PM   #1 (permalink)
ByTeS fLoWiNg ThRu VeIns!
Red face Is NZXT Guardian 921 a good cabinet?
Is it a good cabinet?I absolutely love the looks,and I want a transparent side panel,which made me choose it over NZXT gamma.But the guardian seems to have a flimsier build quality.Please post your opinions/suggestions about this cabinet.
I also like the CM 430 Elite Black,but sadly it lacks cable management.If there are any cabinets with transparent side windows in the same price range,please suggest them
Thanks
ashikns is offline   Reply With Quote
Old 30-06-2011, 08:26 PM   #2 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Default Re: Is NZXT Guardian 921 a good cabinet?
It is a good cabinet, roomy, loads of fans. I heard someguy got a 3k quote for it, great buy at that price.
comp@ddict is offline   Reply With Quote
Old 30-06-2011, 08:36 PM   #3 (permalink)
Yeah,I read some reviews.The temperatures are good.But the front has to be opened to access the optical drive,and that front door looks flimsy from the inside.I believe the CM 430 has steel meshes on front
See this image:
http://www.nzxt.com/new/images/_uplo...g5304_copy.jpg
Old 30-06-2011, 08:53 PM   #4 (permalink)
what price is it... 3k is too low for a cabinet like that.. and read some reviews complaining about poor air flows.. please double check before purchasing.
~ i7 950 | Asus Sabertooth | Gtx 570 | Antec 750W True Power | Corsair 8GB 1600 | Xbox Controller for PC
| WD Green 1 TB | CM Storm ENFORCER | Razer Orca
| Cooler Master Hyper 212+ ~
~ Dell Studio 1555 1080p~
~ Old school : Intel 845GLLY | 256MB | 40 GB | Custom modded LED keyboard | Dead monitor | Remoted ~
~ Kindle ~
~(+ my d3ad brain lol:))~
max.4u is offline   Reply With Quote
Old 30-06-2011, 08:59 PM   #5 (permalink)
Price is 3.7k at primeabgb.com
And the reviews said nothing bad about airflows,owing mainly to the three included 120mm fans.Where did you see it?
Old 01-07-2011, 01:23 AM   #6 (permalink)
iDota
Sarath's Avatar
I remember this. I was in love with this case for its sheer beauty.
But it is a bit smaller and hence will not support high end cards, my only reason to drop it.
There I have given you my pro and con about it. I have researched on it for a week.
Sarath is offline   Reply With Quote
Old 01-07-2011, 08:18 AM   #7 (permalink)
I wont ever be installing high end graphic cards,only mainstream cards ~13k.But I wanna know if it will CM hyper212+ inside it.I also wanna know about the build quality and airflow
Old 01-07-2011, 01:09 PM   #8 (permalink)
abhidev's Avatar
i would suggest CM cabinets....for better air flow
Core 2 duo E4500 2.2gHz , ASUS P5GCMX , 3GB Transcend , Corsair VX 550w, MSI R5770 HAWK Edition 1GB, CM HAF-922, LG W2243T 21.5" LCD, I-Ball Baton
abhidev is online now   Reply With Quote
- by c4u
