Old 30-06-2011, 03:04 PM   #1 (permalink)
arian29's Avatar
Arrow UPS problem..
Please suggest a good UPS. i have mocrotek 800va, luminus 650 va and UMAX 600va and they all failed. I have Corsair 450W smps.
Whenever power goes the system just shuts down.. no backup . Please Help
http://www.twitter.com/arian29
ScAn My AvAtAr
arian29 is offline   Reply With Quote
Old 30-06-2011, 03:08 PM   #2 (permalink)
Default Re: UPS problem..
Whats the configuration of your PC?
Get a APC 800 VA.
If your PC is a low end PC, then the APC 600 VA will suffice.
BTW have you ensured proper earthing?
thetechfreak is online now   Reply With Quote
Old 03-07-2011, 07:39 PM   #3 (permalink)
arian29's Avatar
System config >>
AMD X2 Dual Core 2.6Ghz
4gb ram
ATI Radeon HD 4850
500 gb hddm sata
450 corsair smps..
ScAn My AvAtAr
Old 04-07-2011, 07:27 AM   #4 (permalink)
mithun_mrg's Avatar
I think 600 Va APC is enough for this config also microtek & Luminous are good brands if they failed please check the condition of ur Grid supply with an electritian & also the earthing before installing new UPS
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is online now   Reply With Quote
- by c4u
