30-06-2011, 10:13 AM
Crash Dump Memory
Sry guys if im posting in wrong section, im totally frustated by Crash Dump Memory Error, in this a blue screen comes which shows diff errors.Plz help ASAP coz im totally frustated coz of dis wen i boot my pc after dis error 4beeps comes n den it boot wid single beep or it continue 4 beeps sound again n again n suddenly get started.
I changed by Ram in inserted in diff slot, reinstalled OS,CPU temp reaches max at 48C. Im attaching d pics of errors plz help!!
My Pc config
AMD Phenom X6 1055T,
Gigabyte GA-880GM USB 3.0 Motherboard,
Corsair XMS3 4gb ram,
Zotac Gefore GT430 gfx card,
NZXT Gamma,
Corsair vx450W,
Thanks & Regards,
Pratham
30-06-2011, 11:15 AM
Designer Here
Re: Crash Dump Memory
Wht OS are u using ? what bit?
I just solved mine problem 2 days back
Saw ur pics
U have dxgmms1.sys error. This is related to directx and memory
1. Either ur drivers r conflicting .. update all of them
2. memory Faulty
To test this , type Memory diagonistic tool in start , run it on restart. Let it complete. It will say whether your memory has problem or not. Post the screenshot of the report here
( After the test is complete , u ll come in windows and result will pop up in 2-3 mins )
3. Your graphic card has problem ( rare chance ) . Try updating to latest drivers of gfx card along with directx drivers
80% of problems are due to option2.
I got my RAM replaced and it works fine now on the standby ram given
30-06-2011, 03:15 PM
Thank You Dinesh,
Im using Win7 64bit, i have already insata
lled all latest drivers for mobo n gfx card, will sure try ur suggestion i hope it gonna help me  w/o changing my Ram or gfx card
tried memory diagnostic all clear!! i hope d prbs dnt raise again!!
30-06-2011, 07:48 PM
Dinesh as u said i done dat no memory errors but now i got dat err again for 1ce only
@techfreak : Do i need to overclock???
30-06-2011, 10:33 PM
Super Moderator
If you are getting any memory dumps, post them here. The text files. Will look at them.
01-07-2011, 11:57 AM
@ asingh i dint getu!!,
I hav taken out my gfx card frm mobo but it still gives me crash dump memory errors with blue screen only diff is dat it boots like regular (no 4 beeps scene n den normal boot) plz help is my memory faulty????
01-07-2011, 12:02 PM
Yes memory might be faulty. Try running PC with just one Module (if your RAM is deal channel)
Then the RAM module which will give BSOD will be the faulty one
01-07-2011, 12:31 PM
Super Moderator
Check under c:\memory dumps.
01-07-2011, 12:44 PM
clean the RAM with an eraser and try again.......i too had the same problem long time back...it was due to the carbon collected on the RAM....cleaned it with an eraser...
Core 2 duo E4500 2.2gHz , ASUS P5GCMX , 3GB Transcend , Corsair VX 550w, MSI R5770 HAWK Edition 1GB, CM HAF-922, LG W2243T 21.5" LCD, I-Ball Baton
01-07-2011, 05:21 PM
@ thetechfreak-i have single RAM stick,
@ abhidev- I already done cleaning RAM,
I have taken out my gfx card n d prb havent raised again frm noon, will try again put my gfx card back i hope der cld b some issues in my gfx card or will try formatting my full hdd, I hate formatting n backup d whole data
01-07-2011, 05:36 PM
The graphic card must be culprit
try this:
in the device manager uninstall the card
reboot then tap f8 and choose vga
mode
when windows finishes rebooting
install your drivers
reboot the computer
This might do the trick if the Gfx card is not damaged physically
02-07-2011, 02:08 AM
Designer Here
No need of formattin .. Wnt help.
Do u still get dxgmms1.sys error or the error code changes..
if d code is diff every time its mostly driver conlict or ram problem.
dxgmms1 is a directx problem.
Update ur gfx card and direct x to the latest..
Do a memory test with memtest nw.
if that is clear as well , ur ram is fine..
dload d memtest iso. It is less than 1mb. Burn on a cd and boot
it will complete in around 30 mins. See what it shows..
Btw how old is ur gfx card ? Ram ? Did u upgrade anything in ur pc recently ??
bsod also occurs if u have added a new device with faulty drvers like webcam , tv tuner , audio card , etc..
Try recallin if u did anything new since u r getting bsod
03-07-2011, 08:01 PM
@techking_dinesh: gfx card n ram r just 6months old n i hav already installed all latest drivers n havent upgraded anything in my pc, im getting those diff errors frm last 2-3 weeks, will try memtest!!
AMD X6 1055T, Gigabyte 880GM-USB3, Corsair 4GB DDR3 XMS3 1600MHzNZXT, NZXT Gamma,Corsair VX450W, Zotac GT 430 1GB DDR3,WD Caviar Green 640GB HDD, Samsung 2033 Sync Master,500GB WD Portable HDD
