A guy is offering my a Sony PSP 3004 with the bundled acessories along with a UMD. He says it's used very less and is as good as new. He is selling for Rs 4000. I tried bargaining but he won't budge.
Is it a fair deal?
Also, what should I watch out for when checking it before buying? I have no experience with a PSP
BTW, What's the grey market rate of the PSP 3004??? If it is around 6k, it may not be such a fair deal after all! And is the PSP 2000 available at the grey market? I've heard the 2000's graphics were better.
Graphically they are same. The 3000 version has a brighter screen than the 2000. The 3000 had a few scanline issues when it was launched but i don't know about the current scenario.
Check if it is modded/able.
(Most) 2000s are easy to mod. 3000s weren't moddable when I bought a PSP 2000 2yrs ago. They are moddable now. Not sure how easy that is as I haven't been keeping up.
Also you can buy a new PS2 for 5k.
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
@4000 is a fair deal check every thing i.e Gaming,Video Playback,Wifi,Charging etc before taking also see if u can convince the seller u can keep the set for testing for 1 day before buying
No idea about grey market but i doubt they sell the modded ones in same rate as normal
You can get a PS2 for 5k. So, going for a PS2 will be a better choice as its games are cheaper than that of PSP. But at this price the PSP is a good choice too. Before buying check all features, that mithun has mentioned above.
