Old 28-06-2011, 05:19 PM   #1 (permalink)
Default No beep sounds while booting...monitor powered off
Hi! Digitian I facing an hardware problem, when i turn on the PC it does not boot up, monitor is powered off, plus there's no beep sound at start up, the PSU, Graphic Card, and CPU heat sink fan are working, i hope the information provided is helpful. Twice computer technician came and did some servicing but after couple of days same problem revives.
The assemble Pc config is Mobo: Asus P5Q, Processor: Intel core2duo, PSU: Corsair 450W, RAM: 2x2gb ddr2 Transcend, HDD: 2x2 500 and 1 TB (both Seagate), Optical Drive: Lg dvd 20x, Graphics Card: ATi Radeon 4850
Abhijiet is offline   Reply With Quote
Old 28-06-2011, 05:30 PM   #2 (permalink)
Project Halcyon V2.0
tkin's Avatar
Default Re: No beep sounds while booting...monitor powered off
You need to update the bios, clear cmos, reseat rams and graphics card, you might need the help of a technician.
Project Halcyon v2.0:
[i7 2600k|Asus Z68 VPro|Vengeance 2x4GB|MSI GTX580 Lightning]
[TX 750v2|Seagate 500GB+WD Cav Black 1TB|CM HAF 912 Adv]
[Logitech G110|G500|Adata/750GB+WD/500GB USB 3.0]
[APC 1100VA|XBox 360 Controller|Noctua U12PSE2]
[Siberia Soundcard(Xear 3D)|Koss Portapro|FiiO E6]
[Audio Technica M35|PL30/EOL'ed]
tkin is offline   Reply With Quote
Old 28-06-2011, 05:35 PM   #3 (permalink)
mithun_mrg's Avatar
Dear Abijit
Beep sound comes on completion of a successful POST/BOOT it comes from the Buzzer installed in ur MB, what do u mean by Monitor powered off is it on Power saving Mode
Test with only a single stick of RAM and the GFX card Unplugges and get back
mithun_mrg is online now   Reply With Quote
Old 28-06-2011, 09:40 PM   #4 (permalink)
Wink Re: No beep sounds while booting...monitor powered off
Tomorrow technician will come...fingers crossed.
Old 28-06-2011, 09:50 PM   #5 (permalink)
In Shameful Misery
Scientia Wiz's Avatar
Thumbs up Re: No beep sounds while booting...monitor powered off
remove cmos !
A Sci Wiz HERE ! .............. Believe it or not
Scientia Wiz is offline   Reply With Quote
Old 28-06-2011, 10:10 PM   #6 (permalink)
Hey! Scientia Wiz thanks, i can't remember when was the last time i changed my CMOS battery... will try tht ,
also awaiting technician who's coming tomorrow ...
Hey! tkin i just wanted to know how can i update my BIOS..do i need to flash it, can i flash it through USB drive....or can you explain me how to do it...
Old 29-06-2011, 07:21 AM   #7 (permalink)
mithun_mrg's Avatar
Just install ASUS update from the MB cd and update from NET i would suggest u wait for the Tecnitian if & let him do that
- by c4u
