Old 28-06-2011, 06:35 AM   #1 (permalink)
Night Fury
mayoorite's Avatar
Default APC UPS not working
i have bought br600ci-in APC UPS in April 2010 and in the beginning it gave backup of 9-10 minutes. But after a month or two it gave 1 minute backup only.So i called up the company and they replaced it.Again same thing happens after 2 months and again they replaced. Now they have replaced it three times but now same thing is happening . I have checked my power supply by an electrician and it is perfectly OK.My Pc is old therefore it gives only 10 minutes backup. I have kept ups on charging for 2 days but nothing happened.
Please help me.
mayoorite is offline   Reply With Quote
Old 28-06-2011, 07:27 AM   #2 (permalink)
Default Re: APC UPS not working
I think you might have overloaded it with connecting everything to it. Whats your full config?
thetechfreak is online now   Reply With Quote
Old 28-06-2011, 07:38 AM   #3 (permalink)
mithun_mrg's Avatar
Also check ur earthing and Grid Voltage
mithun_mrg is online now   Reply With Quote
Old 28-06-2011, 07:03 PM   #4 (permalink)
Night Fury
mayoorite's Avatar
Pentium 4 2.4 GHz Northwood ,500 GB Segate HDD,2 GB DDR RAM ,CRT Monitor syncmaster 753s,ADCOM Speakers.
I have only plugged monitor , cpu and modem in ups
Old 29-06-2011, 07:27 AM   #5 (permalink)
mithun_mrg's Avatar
Try using ony the CPU plugged in the UPS Plug the monitor to GRID using a spike guard or Voltage Stabilizer and see the backup time
- by c4u
