Old 27-06-2011, 02:14 AM   #1 (permalink)
Unhappy On board graphics not working
specs:
DH67BL
i5 2500
Sapphire 6870
Firstly, my new Benq g2220 works on both the 6870's DVI ports, but my old Mercury monitor only works on the upper DVI port
Also, the color on the second monitor is way off ...i cant fix it using the monitors settings or CCC...any ideas ?
Finally, should'nt I be able to use the on board GPU ? I can't. Am I missing a driver or something ?
aaronbrako is offline   Reply With Quote
Old 27-06-2011, 08:45 AM   #2 (permalink)
Default Re: On board graphics not working
Have look at these links:
Switchable Graphics 101: The Best Of Both Worlds [Technology Explained]
1 more thing, switchable graphics can only used on Z68 mobos
Intel’s Z68 chipset overcomes the shortcoming of the P67 chipset- which
did not allow users to make use of the
integrated graphics on Sandy Bridge
processors.
MSI Z68A-GD80: Switchable graphics, finally | TECHNOLOGY
thetechfreak is online now   Reply With Quote
Old 27-06-2011, 10:54 AM   #3 (permalink)
mithun_mrg's Avatar
LucidLogix Virtu license is required to be implemented by MB manufaturer for this feature
If ur old old Mercury monitor is CRT try to Degauss & see also check the refresh rate
mithun_mrg is online now   Reply With Quote
Old 28-06-2011, 01:19 AM   #4 (permalink)
Im pretty sure it goes like this:
H67 lets you use the on board graphics but not OC
P67 lets you OC but not use On board graphics
Z68 lets you do both
someone correct me if i'm wrong.
So if I have just one monitor, and i plug it into the Mobo, it should work, right ? It doesnt
Old 28-06-2011, 07:25 AM   #5 (permalink)
mithun_mrg's Avatar
if i am correct
H67 = Onboard Graphics No OC
P67= No GFX OC only possible with K Series processor
Z68=Onboard Gfx & OC only possible with K Series processor Gfx switching possible with Lucid virtue engine
Unplug ur Gfx card and plug ur Monitor to the MB and see if there is no disp RMA ur MB
- by c4u
