Old 25-06-2011, 04:18 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Smile zebronics joypad 150jp no vibration
Hi guys can any one help me on this i bought this zebronics gamepad with vibration model 150jp but windows 7 detects as only generic usb no sign of vibration neither in settings nor in the games. I installed the proper driver as well no use. Any one using this. I even changed new piece still the same
macho84 is offline   Reply With Quote
Old 27-06-2011, 11:13 AM   #2 (permalink)
Default Re: zebronics joypad 150jp no vibration
Most likely you don't have
the driver installed for it, or
else it's not set up correctly.
Go to control panel, game
controllers, and if it is not a
device listed, add it and configure it.
Make sure the PC is virus free and USB drivers of mobo are properly installed.
thetechfreak is online now   Reply With Quote
Old 10-07-2011, 06:45 PM   #3 (permalink)
I had the driver it just showing genric usb joypad not dual shock vibration. I just replaced it the new one with the another.
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/142928-zebronics-joypad-150jp-no-vibration.html
zebronics joypad 150jp no vibration This thread Refback 23-08-2011 11:31 PM
- by c4u
