Old 24-06-2011, 09:34 PM   #1 (permalink)
Default Share files via ethernet
How can i share my files from laptop to pc using an ethernet cable? Both running windows 7
abhijithvarghese is offline   Reply With Quote
Old 25-06-2011, 06:08 AM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: Share files via ethernet
buy a cross-over ethernet cable or make it yourself - it's very simple
http://www.makeitsimple.com/modules....e&pid=8&page=1
ToPsPeEeD = FaSt BuT StEaDy
Old 25-06-2011, 12:00 PM   #3 (permalink)
Fullbring
Zangetsu's Avatar
^^Topgear thanx for the info
Old 25-06-2011, 02:35 PM   #4 (permalink)
1. You can also go for usb-usb cable- http://www.hardwaresecrets.com/artic...-USB-Cable/248 but I don't really think the speed would be like ethernet one.
2. use switch.
Abhinav
abhinav_sinha is offline   Reply With Quote
Old 25-06-2011, 02:48 PM   #5 (permalink)
Fullbring
Zangetsu's Avatar
Originally Posted by abhinav_sinha View Post
1. You can also go for usb-usb cable- Connecting Two PCs Using a USB-USB Cable | Hardware Secrets but I don't really think the speed would be like ethernet one.
wow.. didn't knew it...thanx
Old 25-06-2011, 02:56 PM   #6 (permalink)
In Shameful Misery
Scientia Wiz's Avatar
Cool Re: Share files via ethernet
Connet both of the devices with ethernet cable using a modem !
after that open your browser and then put this address 192.168.1.1
and then open sharing options and forward the setup .
Its done
Simple !
Scientia Wiz is offline   Reply With Quote
Old 25-06-2011, 03:22 PM   #7 (permalink)
New Gen Guru
sujoyp's Avatar
Crosscable is easy to use and speed go around 11 MBPS but u have to still put a fake ip on both the machines to transfer data.
192.168.1.1 sort of
Photography Gears -
Nikon D3100+18-55+55-200+50mm+55mmMicro,
Bag-Tamrac Velocity 6x Bag, Lowelpro pro Runner 200 AW
Yougnou YN-465 flash , Vanguard ESPOD 203AP,
http://500px.com/sujoyp
My flicker link -> http://www.flickr.com/photos/34748095@N07/
Desktop - i3-2100, Intel DH67BL,ADATA 4GB RAM, Seagate 320GB, Corsair CX430
Handset - Samsung Omnia W with Sony MDR-ED12
sujoyp is online now   Reply With Quote
Old 25-06-2011, 04:31 PM   #8 (permalink)
Fullbring
Zangetsu's Avatar
but which will fastest in speed Ethernet method or USB bridge???
Old 25-06-2011, 05:06 PM   #9 (permalink)
mithun_mrg's Avatar
Ethernet of course
mithun_mrg is online now   Reply With Quote
Old 25-06-2011, 05:11 PM   #10 (permalink)
In Shameful Misery
Ethernet is much fast than USB Bridge !
ANYTIME !!!
Old 25-06-2011, 06:27 PM   #11 (permalink)
Fullbring
Zangetsu's Avatar
Originally Posted by mithun_mrg View Post
Ethernet of course
Ok..but in the above article of USB bridge its given USB2.0 is faster than ethernnet....
Old 25-06-2011, 07:27 PM   #12 (permalink)
Its given in the article but I think Ethernet will always be faster as lets suppose the cable may have the capacity to transfer at that speed but the devices will definitely throttle the speed (like having corei7980x in a computer with 512mb 80gb 5400rmp config.).(This is my theory as I have never tested the cable for it.)
Abhinav
Old 26-06-2011, 03:18 AM   #13 (permalink)
Fast 'N' Furious
topgear's Avatar
you're welcome bro
USB 2.0 is faster than 100mbps network but if Op's laptop and desktop comp both have 1 gbps lan interface and OP is is going to use cat 7 cable then it will outperform usb 2.0 - for short length say 4-6 feet usb cable can be used butr for longer length like 50-100 feet ethernet cable should be used.
Old 26-06-2011, 12:01 PM   #14 (permalink)
Cool Buddy's Avatar
If you only want to share files, I don't think you'll need to assign IP address to the machine. Just make the workgroup name same and the machines will show up in network neighbourhood. Set the network type as home or else nothing will show up
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 27-06-2011, 03:29 AM   #15 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ sharing files without ip-address is not possible AFAIK and if he is not assigning any ip-address to the network card installed he will need to get it from some DHCP server and the DHCP server should take care of the ip-address automatically
Old 27-06-2011, 07:42 AM   #16 (permalink)
Cool Buddy's Avatar
Maybe the thing is done automatically in the background, but when I had tried networking 2 PCs, I only made the workgroup name same and they were visible in network neighbourhood. I could browse the shared files and folders from there. I never manually assigned any IP address.
Of course, for anything else one will need to assign or know the IP address of the PC coz otherwise it won't be possible to locate the networked PC from any other machine manually
Nokia 5230 :(
Old 27-06-2011, 10:59 AM   #17 (permalink)
mithun_mrg's Avatar
Maybe u did it through the wizard run on both the PC's
Old 27-06-2011, 11:03 AM   #18 (permalink)
Fullbring
Zangetsu's Avatar
how much is the cost of Cross Cable?
Old 27-06-2011, 11:47 AM   #19 (permalink)
mithun_mrg's Avatar
Apprx Rs. 100 or u can get a Hand made one Cable Cat6 Dlink@Rs 15-20 Per Meter, RJ45 Dlink @ Rs 10-15 per PC
Old 27-06-2011, 03:15 PM   #20 (permalink)
abhidev's Avatar
so what is the basic requirement of this usb cable to attain the speed of 5times more than the Ethernet cable???
Core 2 duo E4500 2.2gHz , ASUS P5GCMX , 3GB Transcend , Corsair VX 550w, MSI R5770 HAWK Edition 1GB, CM HAF-922, LG W2243T 21.5" LCD, I-Ball Baton
abhidev is online now   Reply With Quote
Old 27-06-2011, 03:38 PM   #21 (permalink)
mithun_mrg's Avatar
Simple the Bridge Chip Has to be USB2.0
- by c4u
