24-06-2011, 08:42 AM
Pioneer BDR 205 not detecting in system - help!!!
I am from Bangalore, My friend bought Pioneer Bluray Disc Drive BDR 205. I installed in my system i already have LG DVD RW so i am using both in SATA.
i don't know why still i am not able to see my poineer in my comp , is there any driver cd needed for this. my frd only gave this bluray drive.
any 1 please help me to resolve this.
24-06-2011, 12:27 PM
"Official HD 7970 Owner"
Re: Pioneer BDR 205 not detecting in system - help!!!
Go to the BIOS & check the status read in the Sata Ports.
Sapphire HD 7970 Unboxing
i7 2600k|Ma IV Ex-Z|Venomous X RT - CM R4's Push Pull|16GB RipjawX|Sapphire HD7970 OC, PhysX - Palit SP GTX570|OCZ Vertex 3 120GB|WD Black Raid 0, 40GB[Lisa]|AX850w|Asus Xonar DX, VK278Q|HAF 932|NZXT Sentry II| Logitech G27 Racing Wheel, G15, Attack II-HandBrake, HD C310|Razer DA|Bose Over Ear HP|Powershot HX40IS||E7-00|
IRC Krow
26-06-2011, 10:46 AM
@Sathish:Check whether the sata cable that's connected to this drive is attached securely to your mobo's sata port or not,if necessary remove it and attach it firmly once again.The drive should be recognized in the bios and windows irrespective of whether the necessary drivers have been installed or not.Also ensure that the power cable is connected properly to the drive-its quite possible that the drive isn't functioning because its receiving no power.
@d3p5kor:I think one is permitted to ask questions about hardware related issues here as this place is called "Hardware Q and A"-for buying advice,users have the section called "pc components/configurations" at their disposal.Anyway,nice tagline buddy
26-06-2011, 10:54 AM
Thanks, but the post was created in Buying advice, when i replied...
Now edited..
IRC Krow
26-06-2011, 11:04 AM
Sorry dude-wasn't aware of it.
22-09-2011, 07:37 PM
First of all, Thanks for Repling. In Bios it is detecting in device manager also it is showing.
i upgraded firmware to latest from pioneer website. i don't have BD so i inserted DVD but it is showing as no disc???
please help me out.
Now edited..
i set the region code for india that is 5. so only it is showing.
i am not supposed to set region code? if yes please tell me how to reset it??? i tried with AnyDvd software but no use.
23-09-2011, 09:49 AM
change is constant!!
don't reset region code again and again.. u will be having max 4 chances to change region code.. after that u will not be able to change..
better u try some other options on that..
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
23-09-2011, 06:32 PM
BMG ftw!!
There is no use of region code. So don't change it unnecessarily.
