Old 23-06-2011, 11:13 AM   #1 (permalink)
The Warchief
Kola2842's Avatar
Unhappy Oh god ! Monitor smoking. help :-x
I have a DELL IN1910 19" display. I was watching a movie one hour ago, suddenly i saw some smoke coming out from back of monitor.I just pulled power cable from wall socket.
What is this ? Have i lost my monitor ?
Please help
Kola2842 is offline   Reply With Quote
Old 23-06-2011, 12:07 PM   #2 (permalink)
Default Re: Oh god ! Monitor smoking. help :-x
There is only one way to check this, plug it in and start your PC.
Faun is online now   Reply With Quote
Old 23-06-2011, 01:07 PM   #3 (permalink)
The Sorcerer's Avatar
Are you using a socket extension?
Are you using a surge protector?
Are you using the same cable that was provided with the screen?
Is the socket with 3 pin?
Which amp wall socket?
Is the socket proper?
Are you using VGA only or with one of those DVI-TO-VGA converter?
Is your system grounded properly?
I assume you're not using one of those power cables that powers the screen via the power supply of your system?
Get the wiring and grounding checked, also the ac connection behind your panel.
Hardware BBQ
The Sorcerer is online now   Reply With Quote
Old 23-06-2011, 05:55 PM   #4 (permalink)
The Warchief
Kola2842's Avatar
I plug in again and monitor works fine but there is no movement in CPU . I opened side , there is a green light on mobo.when i push power button nothing happens
I remove and again pluged ram. same result.
Old 23-06-2011, 05:56 PM   #5 (permalink)
In Shameful Misery
Scientia Wiz's Avatar
Wink Re: Oh god ! Monitor smoking. help :-x
You should first confirm that whether the smoke is coming from the socket or the monitor ?
If it is coming out from monitor then check whether it is under warranty or not if it is under warranty then take it to the shop from where you have bought it or go on the dell website and complain about it, if its under warranty then it will be replaced by the company itself !
No need to take tension ! :-P
Scientia Wiz is offline   Reply With Quote
Old 23-06-2011, 06:11 PM   #6 (permalink)
The Warchief
Kola2842's Avatar
Monitor is under warranty but problem now is that CPU is not starting.
Old 23-06-2011, 08:28 PM   #7 (permalink)
In Shameful Misery
Then the problem must be in your CPU !
Check whether you motherboard is well or not !
I think your motherboard may have burnt !
Are there electric voltage variations in your city this may be the reason for it !
Old 23-06-2011, 09:02 PM   #8 (permalink)
The Warchief
Kola2842's Avatar
But there is a green light on motherboard
Is there a way to conform motherboard crash.
Old 23-06-2011, 09:05 PM   #9 (permalink)
Fullbring
Zangetsu's Avatar
Originally Posted by Kola2842 View Post
I have a DELL IN1910 22" display. I was watching a movie one hour ago, suddenly i saw some smoke coming out from back of monitor.I just pulled power cable from wall socket.
Please help
the smoke may be from wires burning....
are all the fans runing inside when u start computer?
Old 23-06-2011, 09:14 PM   #10 (permalink)
The Warchief
Kola2842's Avatar
When i connect power cable then:
1- monitor is same as before.
2-keyboard and mouse have same signals as before.
But:
#there is no light on power switch of cabinet.
# But there is a green light on motherboard below graphics card slot.
#on pressing power switch there is no movement in cpu.NO BEEPS , NO SPIN SOUND.
- by c4u
