Old 21-06-2011, 10:05 AM   #1 (permalink)
ByTeS fLoWiNg ThRu VeIns!
Arrow single channel vs dual channel ram: power consumption?
iam planning to get 4 gb dddr3 ram.which should I choose-single channel or dual channel? am particularly concerned about power consumption.I am planning to buy a core i5 2500 k, asus maximus I V
gene z, ati 5750 running on a cooler master hx 450? so which ram should I choose?
ashikns is offline   Reply With Quote
Old 21-06-2011, 04:08 PM   #2 (permalink)
Default Re: single channel vs dual channel ram: power consumption?
As long as you dont overclock, the PSU should do just about fine.
But if budget permits, get a Corsair GS600 @Rs.4000
Dont worry RAM is not the most major power consuming device. Processor and Graphics card are the main ones
thetechfreak is online now   Reply With Quote
Old 21-06-2011, 04:19 PM   #3 (permalink)
is there any notable performance difference between single channel and dual channel?
Old 21-06-2011, 04:21 PM   #4 (permalink)
Have a look at this test. Very interesting read and results
Test Results: Single Vs. Dual Channel RAM : Parallel Processing, Part 2: RAM and HDD
Old 21-06-2011, 05:48 PM   #5 (permalink)
Thank you very much it seems there is not much performance difference, so I'll go with single channel
Old 21-06-2011, 05:57 PM   #6 (permalink)
channel
No problem! Happy to help
- by c4u
