Old 19-06-2011, 01:41 AM   #1 (permalink)
Default Wifi Router Netgear WGR614 problem
Hi,
I have successfully configured this router using a Ethernet cable and able to use internet using wifi as well, but after a interval of 15-20 minutes internet got disconnected and my laptop is not able to find out and WiFi signal as well. I had tried searching wifi signal through another laptop but got same result. After switching off and on router again I am able to get the signal. I am using a Acer 5745g laptop which uses broadcom 802.11n WiFi network adapter.
kindly help me in this regard.
TIA
Vinod Kumar
kumarvin8 is offline   Reply With Quote
Old 20-06-2011, 12:17 PM   #2 (permalink)
mithun_mrg's Avatar
Default Re: Wifi Router Netgear WGR614 problem
If ur getting the same problem using another Laptop then probably its the Router problem try updating the firmware of the router & see if the problem persists take it to the service center
mithun_mrg is online now   Reply With Quote
Old 20-06-2011, 01:41 PM   #3 (permalink)
Wise Old Mouse
mrintech's Avatar
+1
* Try updating the Firmware
* Make sure there's LESS Obstructions in between your router and Laptop
* In 10.0.0.1, under Setup >> Wireless Settings, select:
# Mode => Upto 150 Mbps
#Security Options => WPA-PSK [TKIP] + WPA2-PSK [AES]
Last option, go to service center if the problem persists
Hope this helps
- MrinTech :)
mrintech is offline   Reply With Quote
Old 29-07-2011, 05:56 PM   #4 (permalink)
Hi its me mak here i prefer that u reset the router by admin login and then ur problem will be solved........................
MAK5577 is offline   Reply With Quote
- by c4u
