Old 18-06-2011, 10:29 PM   #1 (permalink)
Rockstar11's Avatar
Unhappy no wireless light. Netgear WG602 v3 54 Mbps
My Netgear WG602 v3 54 Mbps wireless router worked fine for about 3 months.
All of a sudden, wireless indicator light is not coming on.
only power light, ethernet light is on.
wireless light indicator is off.
using BSNL modem with Ethernet cable.
help please..
Rockstar11 is online now   Reply With Quote
Old 19-06-2011, 01:45 PM   #2 (permalink)
Default Re: no wireless light. Netgear WG602 v3 54 Mbps
Try doing a factory reset and see if it helps.
Also here is a Google search to help you -
wireless light off Netgear WG602 v3 - Google Search
thetechfreak is online now   Reply With Quote
Old 19-06-2011, 06:20 PM   #3 (permalink)
Rockstar11's Avatar
factory reset bhi try kiya.. kuch hua nahi..
aur netgear ka setup page bhi nahi khul raha..
defalut access
http://192.168.0.227
Old 20-06-2011, 12:11 PM   #4 (permalink)
mithun_mrg's Avatar
connect the router directly to ur pc assuming ur using winxp go to control panel >Network Connections>Local Area Connection>Right Click>Properties>Internet Protocal(TCP/IP) Set the IP TO-192.168.0.210 Subnet:255.255.255.0 Open the 192.168.0.227Address in ur Browser ur Router setup page should Open
If not trying checking in another PC
mithun_mrg is online now   Reply With Quote
- by c4u
