Old 17-06-2011, 02:05 PM   #1 (permalink)
mastercool8695's Avatar
Default 600VA UPS(Proview 600) problem
i have a 600VA UPS(Proview 600) ups (whatever you call it).
it makes huge noise when it starts...
is there anyway how to stop that????
and at the time of powercuts, it keeps shouting every second..(yes every second)
what to do?
is there any way to fck the speaker off??
better ask for autograph buddy....:-D:-D
Help Needed : http://www.thinkdigit.com/forum/pc-c...n-15-20-k.html
mastercool8695 is offline   Reply With Quote
Old 18-06-2011, 08:38 AM   #2 (permalink)
mithun_mrg's Avatar
Default Re: 600VA UPS(Proview 600) problem
Just take it to any electronics repair shop & remove the Buzzer/Speaker normally it is soldered in the pcb
mithun_mrg is online now   Reply With Quote
Old 25-06-2011, 07:08 PM   #3 (permalink)
charging it for how much time is adviced???
so that a good backup time is insured??
Old 25-06-2011, 07:17 PM   #4 (permalink)
Don't you think that will defeat the very purpose of having UPS
Faun is online now   Reply With Quote
Old 26-06-2011, 10:11 AM   #5 (permalink)
quicky008's Avatar
Removing the buzzer is not advisable-you should ask a knowledgeable technician to inspect your ups and carry out the necessary repairs to fix this issue.Repairing it won't be too difficult i think-it'll be better still if you can contact proview's service centre for getting it repaired.
Keeping the UPS running for atleast 3-4 hours will ensure that the batteries have recharged fully-depending on your PC's power consumption,the backup time may well range anywhere between 5 mins-15 mins or more.
quicky008 is offline   Reply With Quote
- by c4u
