Old 17-06-2011, 01:58 PM   #1 (permalink)
Adam young
sukesh1090's Avatar
Default Doubts about corsair cx 430w
Guys i just want to know that is this psu is reliable or not because some say it is good but some say it is not.so i want to get a clear picture about this psu.
Thank you.
:razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
sukesh1090 is offline   Reply With Quote
Old 22-06-2011, 04:26 PM   #2 (permalink)
Default Re: Doubts about corsair cx 430w
Its a good PSU. 80% efficiency.
Get all info here-
Builder Series™ CX430 — 430W Power Supply
some specs-
Corsair Builder Series CX430 Features:
Supports the latest ATX12V v2.3 standard and is backward compatible with ATX12V 2.2 and ATX12V 2.01 systems.
Rated up to 430W of continuous power output at 30°C
Ultra-quiet 120mm fan delivers excellent airflow at an exceptionally low noise level by varying fan speed in response to temperature.
Up to 80% energy efficiency means less heat generation and lower energy bills.
0.99 Active Power Factor Correction provides clean and reliable power.
Universal AC input from 90~264V. No more hassle of flipping that tiny red switch to select the voltage input!
Dedicated single +12V rail offers maximum compatibility with the latest components.
Over-voltage and over-power protection, under-voltage protection, and short circuit protection provide maximum safety to your critical system components.
Extra long fully-sleeved cables support full tower chassis.
Two year warranty and lifetime access to Corsair's legendary technical support and customer service.
Dimensions: 5.9"(W) x 3.4"(H) X 5.5"(L); 150mm(W) x 86mm(H) x 140mm(L)
MTBF: 100,000 Hours
thetechfreak is online now   Reply With Quote
Old 22-06-2011, 05:28 PM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Isn't FSP Saga 500W available for same price and I think it is a better PSU.
PS: I never tried CX series so can't comment on quality of CX430.
desiibond is offline   Reply With Quote
Old 23-06-2011, 05:07 AM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
@ OP - make the decision yourself
Corsair CX430 Preview- Sixth page
ToPsPeEeD = FaSt BuT StEaDy
- by c4u
