Old 17-06-2011, 12:20 PM   #1 (permalink)
The Warchief
Kola2842's Avatar
Default DVD drive problem
hi ! I have a sony dvd writer. It was working very fine yesterday , i bought a tekken tag tournament ps2 dvd then insert it in drive worked fine and i enjoyed game using PCSX-2 0.9.8 for about one hour , then shut down my pc .
Again started and insert same disk .Suddenly my pc get hanged , so i just press reboot button and restart it.BUT NOW it doesn't read any kind of disk . Green light which used to blink not doing so and just remains green.
I tried device manager to uninstall drive and restart , but problem remains same I'm not able to play any game.
What should i do . Please help..
PC CONFIGURATION :
Asus P5KPL-AM/PS
INTEL Core 2 duo 2.93 GHz
2 GB DDR2 ram
320 GB HDD
512 mb ASUS EN 8400 GS
Kola2842 is offline   Reply With Quote
Old 17-06-2011, 12:23 PM   #2 (permalink)
Fullbring
Zangetsu's Avatar
Default Re: DVD drive problem
@Kola2842: Lens of DVD writer is faulty
Old 17-06-2011, 01:00 PM   #3 (permalink)
The Warchief
Kola2842's Avatar
So should i clean it ?
@zangetsu Btw thanks for reply
Old 17-06-2011, 01:17 PM   #4 (permalink)
Fullbring
Zangetsu's Avatar
Obviously yes,using a DVD lens cleaner or by isopropyl alcohol (by opening the drive if u r an expert)
Old 17-06-2011, 06:03 PM   #5 (permalink)
The Warchief
Kola2842's Avatar
@zangetsu I'll try and reply soon...
My friend knows how to clean so i'm going to his house . Take a little time..
Hey i cleaned my lense with alcohol but problem remains same.....green light stays green and doesn't blink
when i insert a disk , mouse pointer shows disk but nothing happens
Old 17-06-2011, 06:07 PM   #6 (permalink)
Multiplex Of Technology
TechPlex's Avatar
Just remove that PS simulator app. And then tell what happened. Maybe the app is playing with your drive.
Technology is just like time. Never stops. Keeps changing...
TechPlex is offline   Reply With Quote
Old 17-06-2011, 06:23 PM   #7 (permalink)
The Warchief
Kola2842's Avatar
I checked drive on another pc , same result
Old 17-06-2011, 08:35 PM   #8 (permalink)
Technoholik !!
Tech&ME's Avatar
Tell us "
1. can you tell us if the tray is opening and closing normally or not ??
2. Does the CD/DVD in the tray spins and then stop with out any result ?
3. Which CD/DVD are you trying to test the drive ?
[Desktop]
[Laptop]
Tech&ME is online now   Reply With Quote
Old 17-06-2011, 08:42 PM   #9 (permalink)
The Warchief
Kola2842's Avatar
1-Tray is working normally
2-i used many movies , mp3 and ps2 game dvd
3-:-/According to sound i think there is no spinning.:-/
Old 17-06-2011, 09:21 PM   #10 (permalink)
Technoholik !!
Tech&ME's Avatar
ok so, according to you there is no spinning.
Now its clear that some parts have moved inside your DVD Drive.
What I am expalining below is not for newbies (please consider doing it if you are confident enough)
Step 1 : Open the DVD Drive cover.
Step 2 : Clean the lens with a cotton cloth (with some camera lens cleaner).
Step 3 : Move the lens manually back and forth with your hands.
Step 4 : Look for loose connections, screws etc and tighten it. (don't put your force on it)
Step 5 : Replace the TRAY and Cover it back.
Step 6 : Install it on your computer and see if things go RIGHT!
If the above procedure doesnot help take risk in doing the following :
You Tube Video
[Desktop]
[Laptop]
Old 17-06-2011, 09:36 PM   #11 (permalink)
The Warchief
Kola2842's Avatar
Great Cool Thanx it now works again
you all rocks thanxxx a lot.
Old 17-06-2011, 09:51 PM   #12 (permalink)
Technoholik !!
Tech&ME's Avatar
Okay !! nice to hear that
[Desktop]
[Laptop]
- by c4u
