Old 16-06-2011, 01:43 AM   #1 (permalink)
Default LCD MONITOR cleaning
my first qn in TDF
To all the forum members who are having LCD monitors
how do u keep it clean from spots and scratches?
urmisona is offline   Reply With Quote
Old 16-06-2011, 02:46 AM   #2 (permalink)
Anish's Avatar
Default Re: LCD MONITOR cleaning
Cover it when not in use,
avoid keeping the monitor near windows
clean with lcd cleaning cloth and solution to eliminate spots.
and scratches - - - - what do you mean? like appearing on cell phone screens? what in the world do you rub your lcd to get scratches?
The secret ingredient is nothing
Anish is offline   Reply With Quote
Old 16-06-2011, 05:46 AM   #3 (permalink)
jsjs's Avatar
We can get spots on lcd but scratches? thats weird
My brand new siggy
jsjs is offline   Reply With Quote
Old 16-06-2011, 12:09 PM   #4 (permalink)
Super Moderator
asingh's Avatar
Basically keep it covered. And never open any liquid content or keep spill-able liquids near it. I was opening a tube of ELFY near my DELL 24", and it squirted on the screen. Bottom left and middle bottom. Luckily it adhered to transparent, but it can never be removed now.
asingh is online now   Reply With Quote
Old 16-06-2011, 02:25 PM   #5 (permalink)
Adam young
sukesh1090's Avatar
Use transparent screen guards,but u only need this if you use your lcd badly otherwise getting scratches is very very rare case.
For spots use lens cleaning liquid.
:razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
sukesh1090 is offline   Reply With Quote
Old 16-06-2011, 04:11 PM   #6 (permalink)
avichandana20000's Avatar
where is this lens cleaning liquid (a good one) available?
Distill water+vinegar(ratio 50:50) will do ?
NZXT PHANTOM WHITE|GA990XA UD3|955BE 3.6(O.C.ed)|MX-2|HYPER EVO|SAPPHIRE 6670 DDR5|DELL SP2309W|CORSAIR XMS 2X2GB 1333|450VX|SEAGATE 1TB|LOGITECH G110|APC 650 VA|
avichandana20000 is online now   Reply With Quote
Old 16-06-2011, 04:18 PM   #7 (permalink)
thanks guys. what actually has happened is my little daughter has spilled some water on it . i have mopped it immediately but dried waterspots are there. and i do not want to use anykind of cloth which can make scratch.
if majority supports that distill+vinegar i will try that.
Old 16-06-2011, 10:13 PM   #8 (permalink)
Anish's Avatar
Donno whether it will work, you better clean with the lcd cleaning solution... it will be available in local computer spare shop. It works like charm.
Old 17-06-2011, 02:36 PM   #9 (permalink)
Adam young
sukesh1090's Avatar
You can also get this solution in lens or spectacle shop.
-Rifleman's Creed
Old 18-06-2011, 04:22 PM   #10 (permalink)
what to say there?
Old 20-06-2011, 05:40 AM   #11 (permalink)
saswat23's Avatar
Originally Posted by avichandana20000 View Post
what to say there?
Ask them for Lense (Spectacles) cleaners.
i5-2400 | P8H67M-EVO | DRW 24B3ST | WDC Blue 500GB | VENGEANCE 4GB DDR3 | FSP SAGA-II 500W | Zebronics Aviator | DELL IN2020M | MS Wired 500 Combo | Creative A-35 | iBall Rocky Headset
saswat23 is offline   Reply With Quote
Old 23-06-2011, 04:21 PM   #12 (permalink)
ajayritik's Avatar
I remember earlier we used to get some covers for the CRT Monitor, Cabinet, Keyboard, printer etc which were made of a material which was like thin cloth. Not sure which material it was. My cousin told me that material will absorb less dust it seems. Can we use these covers to cover the LCD Monitor?
ajayritik is online now   Reply With Quote
Old 25-06-2011, 07:10 AM   #13 (permalink)
Anish's Avatar
Sure thing friend.. Those things are nice to cover.. Do protect them (I mean dont throw these cover somewhere in dust or in corner of your home.. it will be easily damaged.)
Old 03-08-2011, 04:38 PM   #14 (permalink)
ajayritik's Avatar
Guys just checking on the LCD Tips to keep it neat and clean. Found some useful tips here. Was checking what kind of covers do we get for LCD Screens. As mentioned in my previous post we used to get some dust resistant covers earlier and I used it for my CRT monitor. Will that do? I also see someone here mention about some transparent cover being available for this screen. Is this similar to the ones some people used with their Televisions. Also is there any name for the Solution which is used to clean the Screen. I find some spots now on the screen.
Old 03-08-2011, 06:08 PM   #15 (permalink)
a_g = JPKN
s18000rpm's Avatar
use colin cleansing spray and a baniyan.
thats all.
if u buy a cloth for lcd's, then buy a proper lint free cloth, dont do kanjoosi.
the yellow clothes, avoid them like plague.
those pos might even leave their yellow stains on surfaces.
and dont use vinegar based cleansers, vinegar is for glass not delicate plastic
finally DONT LET KIDS NEAR PC, especially keyboards, unless you clean it everyday wit some cleansing solution.
i clean kb and mouse every day with colin spray.
ASUS K53SV SX520D + BF3
s18000rpm is online now   Reply With Quote
Old 03-08-2011, 06:15 PM   #16 (permalink)
Hmmmmm
Tenida's Avatar
You can also use distilled water with microfiber cloth.I clean my monstermonitor this way
Tenida is offline   Reply With Quote
Old 03-08-2011, 07:26 PM   #17 (permalink)
Dust in the Wind
Skud's Avatar
Can cotton be used?
Gaming Rig:
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 || Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
C2D E7400 || Gigabyte EP45-DS3R || 2x2GB DDR2 800 || 9TB || MS Wireless Desktop 2000 || Gigabyte 5770 || Samsung 32" || Seasonic SII 520W || Silverstone LC10
Samsung Galaxy R I9103
Will be off/irregular for a month...
Skud is offline   Reply With Quote
Old 03-08-2011, 07:32 PM   #18 (permalink)
Super Moderator
asingh's Avatar
It will leave a ton of lint behind.
Old 03-08-2011, 07:42 PM   #19 (permalink)
Dust in the Wind
Skud's Avatar
And what is this microfiber cloth? Where to get one?
Gaming Rig:
HTPC Rig:
Old 03-08-2011, 09:13 PM   #20 (permalink)
Hmmmmm
Tenida's Avatar
^^Arey the cloth given with spectacles or screen guards
Old 03-08-2011, 09:24 PM   #21 (permalink)
Dust in the Wind
Skud's Avatar
OK, got it.
Gaming Rig:
HTPC Rig:
Old 04-08-2011, 01:58 PM   #22 (permalink)
ajayritik's Avatar
Guys do we get any branded lint free clothes? Also what about the cover for the LCD? Does anyone use the cover?
Old 05-08-2011, 12:06 AM   #23 (permalink)
→|Requiescat| |in| |Pace|
soumo27's Avatar
I use the cover provided with my monitor. And the lint free cloth+a lil water works fine to clean the monitor...
__Phenom X2 550 BE @ 3.3 Ghz | Asus M2968AM-PLUS | Kingston 2 GB DDR2 | Seagate 500 GB | Sapphire HD 6670 1 GB | FSP SAGA II 500 W :twisted: | X360 Controller__
soumo27 is offline   Reply With Quote
- by c4u
