Old 15-06-2011, 08:37 PM   #1 (permalink)
Default Cooler Master 430 Elite temps high ???
Hey guys ...
Are these temps too high for my cpu ???
Everest Ultimate Stress Test running for 1/2 hr (Didnt have much patience )
Time : 10 mins b4 uploading ..
Condition : No Air Conditioning ... Just a normal room ...
I invested in an Artic silver matrix thermal compound 2day ... Planning to apply it tommorow ... Also will do some cable management if possible ....
The temps remain constant for the high values thats why I quit the test ...
Also can I or SHOULD I mess with around overclocking my cpu on stock cooler ??? I don`t need it but just to check it out ??? Is it worth ???
Intel i5 760 || Asus P7P55D-E || Corsair 2X2 Gb DDR3Kit || Corsair GS 600 || WD Green 1 TB || XFX 4350 || CM 430 Elite || Samsung B2230
vizkid2005 is offline   Reply With Quote
Old 15-06-2011, 09:23 PM   #2 (permalink)
jsjs's Avatar
Default Re: Cooler Master 430 Elite temps high ???
Temps in the range of 40 are fine. Dont oc on stock
My brand new siggy
jsjs is offline   Reply With Quote
Old 15-06-2011, 09:38 PM   #3 (permalink)
U see in the pic ... The temps are in 70`s on full load ... Are they ok ???
Old 15-06-2011, 10:32 PM   #4 (permalink)
Treatment in progress...
mukherjee's Avatar
See this here
Package Specifications
Max CPU Configuration1
TCASE72.7°C
Package Size37.5mm x 37.5mm
Processing Die Size296 mm2
# of Processing Die Transistors774 million
Sockets SupportedLGA1156
Halogen Free Options Available|Yes
Seems u are crossing the Tcase bro!
Consider wire management or a better HSF...
Cud u post cabby screenshots?
PC: Core i7 2600K||Z68V Pro||Noctua U12P SE2
Vengeance 1600Mhz 8GB||GTX560Ti HAWK
CM Elite 430||1TB+300GB
VX550||G110||G1 mouse||Razer Goliathus
Photography: Nikon D5100||Nikon 55-300 VRII
Canon Powershot SX220HS||Tamrac Velocity 9x
Audio Gear: Brainwavz M4||Meelec A151|| EP630
PX100 II||Fiio E5||AudioTechnica ATH-T500
mukherjee is offline   Reply With Quote
Old 16-06-2011, 03:13 PM   #5 (permalink)
I`ll do it 2morrow ... Pakka !!!!
This is how my Pc looked Yesterday ....
And the Temps are as above ..
Yesterday .. I had gone to Lamington road and invested in a Arctic silver MATRIX Thermal Compound ... I thought it will help bring the temps down ...
2day I opened my Pc ....
Cleaned Everything ....
PC Fan and Heat sink Before and After ...
Cleaned Earlier thermal compound with Iso Propyl Alcohol (IPA)
Case fan Before ...
Case fans After cleaning ...
I applied the paste using the center drop method ... I cleaned cpu and heatsink base with Iso Propyl Alcohol before putting paste on it ...
I used this net to cover fan Inlets and outlets ....
This is Finally how my Pc looks now .... Tried my best At cable management ..
But the temps are HIGHER than what they were on yesterday !!!!
This is When I just booted after cleaning ...
I turned the test off As soon as the temps went soaring !!!
This is during I was writing my post ....
This was the latest ....
What did I do Wrong ???
I`m really Worried !!! What do I do now ???
The compound was supposed to bring my cpu temps down ....
Now what ???
Old 16-06-2011, 03:40 PM   #6 (permalink)
mukherjee's Avatar
the Matrix thermal compound requires break in time of about 300hrs
Important Reminder:
Due to the unique carrier fluid used and the shapes and sizes of the thermally conductive particles in Matrix, it will take a minimum of 300 hours and multiple thermal cycles to achieve maximum particle to particle thermal conduction and for the heatsink to CPU interface to reach maximum conductivity. (This period will be longer in a system without a fan on the heatsink.) On systems measuring actual internal core temperatures via the CPU's internal diode, the measured temperature will often drop significantly over this "break-in" period. This break-in will occur during the normal use of the computer as long as the computer is turned off from time to time and the interface is allowed to cool to room temperature. Once the break-in is complete, the computer can be left on if desired.
Old 16-06-2011, 03:41 PM   #7 (permalink)
Hmmmmm
Tenida's Avatar
I think you need good after market CPU cooler like Coolermaster Hyper 212+ with 2 higher rpm fan. if the temperature remains at higher degree
Tenida is offline   Reply With Quote
Old 16-06-2011, 03:49 PM   #8 (permalink)
Quite funny
Faun is online now   Reply With Quote
Old 16-06-2011, 04:46 PM   #9 (permalink)
@ mukherjee : Dude its written dat significant temp drop will be seen during this "break in" period ... I don`t see any change ... In fact temps have risen ....
^^ I can`t buy an after market cooler now ... No $$$ .. Have to save up money ....
I am planning to buy N620 .... But I don`t understand other ppl with same proccy don`t have heating probs .. then why me ???
U see in above pics .. I tried my best at cable management ...
Old 16-06-2011, 05:16 PM   #10 (permalink)
^^keep your system open and see the temps going lower or not.
Old 16-06-2011, 05:19 PM   #11 (permalink)
mukherjee's Avatar
Agreed...u did a good job at cable management...even better than me
What I meant is that the matrix requires 300hrs at least to achieve maximum/optimum efficiency of heat conduction...comes to about 12.5 days!
Old 16-06-2011, 07:05 PM   #12 (permalink)
Hmmmmm
Tenida's Avatar
I think HSF is not installed properly or might be broken.Please check it.I am having same problem years ago.
Old 16-06-2011, 08:27 PM   #13 (permalink)
Super Moderator
asingh's Avatar
Some TIMs have a curing in period.
asingh is online now   Reply With Quote
Old 16-06-2011, 09:58 PM   #14 (permalink)
Project Halcyon V2.0
tkin's Avatar
See this here
Tcase is the surface temp for intel, totally unrelated to core temp, tjmax gives max core temp, to measure tcasemax you need to put a thin thermal probe by drilling a cut on top of the HSF.
So anything below 90c for core temp is not gonna throttle, but for safe practice 80c should be considered max limit under IBT.
@ OP, tug on the cooler, does it move? Tug on the cooler feet, do they move? If no, let the Matrix settle, one thing, matrix is not a good compound, get TX4, it does not need curing, my Noctua NTH1 required 1/2hr curing time(the time required for the paste to melt and fill the grooves).
Project Halcyon v2.0:
[i7 2600k|Asus Z68 VPro|Vengeance 2x4GB|MSI GTX580 Lightning]
[TX 750v2|Seagate 500GB+WD Cav Black 1TB|CM HAF 912 Adv]
[Logitech G110|G500|Adata/750GB+WD/500GB USB 3.0]
[APC 1100VA|XBox 360 Controller|Noctua U12PSE2]
[Siberia Soundcard(Xear 3D)|Koss Portapro|FiiO E6]
[Audio Technica M35|PL30/EOL'ed]
tkin is offline   Reply With Quote
Old 16-06-2011, 11:10 PM   #15 (permalink)
@ tkin : Yes dude .. I know its fixed properly .. Its solid and doesnot move ....
But I don`t wanna buy another thermal now .. I`ve used matrix just once .... I guess I`ll wait till it CURES ... freaking 300 hrs !!!
@tenida : How did u solve urs ???
Old 16-06-2011, 11:21 PM   #16 (permalink)
Hmmmmm
Tenida's Avatar
I have applied cheap Intel branded thermal paste(rs 100) in my Core 2 Duo E7300 and also change the hsf because it leg was broken
Buy TX4 as suggested by tkin to solve the problem.
Old 16-06-2011, 11:32 PM   #17 (permalink)
@faun : Yeah .. it drops by a mere 1 degree celcius ... The prob is that I want to lower temps with the side panel on .... What the point of removing the side panel everytime ???
Old 17-06-2011, 12:56 AM   #18 (permalink)
Well then obviously the problem lies between heatsink and CPU die. May be they are not spliced up perfectly.
I don't think thermal paste will make huge improvement. Maybe 3-4 degree cel.
Also, can you tell me from where you improvised that dust filter net ? I want one too.
Old 17-06-2011, 01:03 AM   #19 (permalink)
Super Moderator
asingh's Avatar
Give it a few IBT runs. Will cure it fast.
Old 17-06-2011, 04:35 AM   #20 (permalink)
Fast 'N' Furious
topgear's Avatar
@ vizkid - what's your CPU vcore ? Try to set to 1.25v or 1.22V under bios settings.
ToPsPeEeD = FaSt BuT StEaDy
Old 17-06-2011, 12:16 PM   #21 (permalink)
@Faun : I had got that net to keep out pigeons from making nests on my Ac ka outside part (Dunno what they call it ... ) .. I had some of it left .. So I cut it out in shape of a square ... Made four holes with scissor ... N Just fixed the fans ...
Guys , Luk what happened to my Case when I used incense sticks ( Agarbatti ) to check airflow in my pc ... :fluriod-cry2:
@ Asingh : Whenever I try .. It soars high ... It reaches 75 in 3 secs !!!! Then I get worried and turn it off ....
@ topgear : Its set to Automatic ... No OC profile defined in my BIOS ... Its all on Default ....
Hey guys that thermal compound I got is leaking from the top side ... WTF !!!!
- by c4u
