Old 15-06-2011, 12:24 AM   #1 (permalink)
avichandana20000's Avatar
Default corsair 450 vx, need prompt reply
1)what is the power cord of this PSU look like(india or american)(googling does not help out)
2)will it work with APC 650V UPS
3)Is a Belkin spike buster required for this
i am going to fit this in Asus M4A78-TE mobo
i amgoingto be the proud owner of this tomorrow morning.
thanks in advance
NZXT PHANTOM WHITE|GA990XA UD3|955BE 3.6(O.C.ed)|MX-2|HYPER EVO|SAPPHIRE 6670 DDR5|DELL SP2309W|CORSAIR XMS 2X2GB 1333|450VX|SEAGATE 1TB|LOGITECH G110|APC 650 VA|
avichandana20000 is online now   Reply With Quote
Old 15-06-2011, 03:44 AM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: corsair 450 vx, need prompt reply
the power cord is american type and if the UPS has Indian type power sockets just use your old PSu cord or buy a 3 pin monitor power cord for as low as Rs. 20.
ToPsPeEeD = FaSt BuT StEaDy
Old 15-06-2011, 09:36 AM   #3 (permalink)
Mmmph!!!
doomgiver's Avatar
congrats, im using the same smps too, very good performance (i too used my old psu cable, in fact, i have a few lying around, want one? )
Mmmphh-mphhhh-mmphh mhh!!!
Steam : doomgiver
doomgiver is offline   Reply With Quote
Old 15-06-2011, 09:44 AM   #4 (permalink)
MegaMind's Avatar
The pow cord supplied with VX450 is best quality one...
I suggest using a converter like this...
i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - 1TB 7200.12 - 9800GT - CM M600 - NZXT Gamma - XONAR DX + VS4121/XB500 - OptX AW2210
MegaMind is offline   Reply With Quote
Old 15-06-2011, 10:09 AM   #5 (permalink)
i have already purchased a belkin surge protector before hand keeping this in mind. will this servethe purpose?
Old 15-06-2011, 10:24 AM   #6 (permalink)
i am not able to see the picture i have attached, not even after clicking on it. It's showing a cross but the picture given by megamind is clearly visible.what is the problem?
Old 15-06-2011, 10:25 AM   #7 (permalink)
Super Moderator
asingh's Avatar
This will do.
asingh is online now   Reply With Quote
Old 15-06-2011, 10:34 AM   #8 (permalink)
thanks to all.
@ Asingh. have u been able to see the picture i have attached?
Old 15-06-2011, 10:36 AM   #9 (permalink)
Super Moderator
asingh's Avatar
Yes. The socket surge protector.
Old 15-06-2011, 10:44 AM   #10 (permalink)
Dust in the Wind
Skud's Avatar
Yes the attachment is clearly visible and it will do the job.
Gaming Rig:
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 || Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
C2D E7400 || Gigabyte EP45-DS3R || 2x2GB DDR2 800 || 9TB || MS Wireless Desktop 2000 || Gigabyte 5770 || Samsung 32" || Seasonic SII 520W || Silverstone LC10
Samsung Galaxy R I9103
Will be off/irregular for a month...
Skud is offline   Reply With Quote
Old 15-06-2011, 11:09 AM   #11 (permalink)
but i am not able to see the picture myself. it appears as a small redcross. why is this so? even in other sites also some pictures are appearing as redcross only.
Old 15-06-2011, 11:12 AM   #12 (permalink)
Dust in the Wind
Skud's Avatar
Which browser are you using? Either your ad-blocking extension or your security suite is blocking it.
Gaming Rig:
HTPC Rig:
Old 15-06-2011, 11:31 AM   #13 (permalink)
IE8 and KIS2011.
Old 15-06-2011, 11:49 AM   #14 (permalink)
Dust in the Wind
Skud's Avatar
Must be KIS then. Can you post a screenshot of the same?
Gaming Rig:
HTPC Rig:
Old 15-06-2011, 03:34 PM   #15 (permalink)
i am in office now, so i will post it later. Btw what to post is not clear to me. Again if Megamind's picture can be seen by me then why my picture is not visible? Also i am able to see many pictures in other threads in TDF.
Confirm please.
Apart from 20+4 pin, Corsair 450 vx is having two cpu power connectors: one 8 pin and another 4pin.
My board is Asus m4a78t-e which has 4pin Atx12v. So the 4pin of CA will go to 4 pin of Asus mobo. is that a correct diagnose?
What is the use of 8pin then?
i am asking this because this time i will do the job in my own hand and i know you are there to help me. thanks.
Old 15-06-2011, 04:05 PM   #16 (permalink)
Dust in the Wind
Skud's Avatar
Only one 8pin CPU power connector is there which can be split into 2. So if your mobo takes 4pin insert one part, that's it.
Check the tech specs here:-
http://www.corsair.com/power-supplie...-1/vx450w.html
Gaming Rig:
HTPC Rig:
Old 15-06-2011, 04:31 PM   #17 (permalink)
Super Moderator
asingh's Avatar
Correct. The 8 PIN is the EPS 12V connector. It can be split to give the 12V direct to the socket next to the motherboard.
From where you found a 4 PIN connector on that supply.
Old 15-06-2011, 05:02 PM   #18 (permalink)
Dust in the Wind
Skud's Avatar
Probably some old reviews. I was looking at the johnnyguru, techpowerup reviews during 2007 and it was mentioned like that.
Gaming Rig:
HTPC Rig:
Old 15-06-2011, 05:06 PM   #19 (permalink)
This picture is displayed in NEWEGG site. it seems that there are two separate cords as the level suggests. you can judge better.
again i am not able to see the pic from my office also. is there any problem in my TDF id itself.
Old 15-06-2011, 05:09 PM   #20 (permalink)
Super Moderator
asingh's Avatar
You office is blocking images.
That image is incorrect for the VX450. It would have the 8 PIN. Yours has 2x EPS12 wires..?
Old 15-06-2011, 05:16 PM   #21 (permalink)
i am seeing this when i attach picture.
Old 15-06-2011, 05:27 PM   #22 (permalink)
but then why it is not blocking other's picture but only mine. same thing is happening in my home also.
My goodness. Such a reputed online site providing wrong pictures!! and they are not updating it also
cannot understand 2 x EPS12 wires. Are u talking of my current PSU?
In my mobo manual 20+4 pin is named as EATXPWR and the 4pin as ATX12V.
Old 15-06-2011, 05:36 PM   #23 (permalink)
Dust in the Wind
Skud's Avatar
The older VX450 had those connectors. Check this:-
Corsair VX450W Review - Page 1/5 | techPowerUp
Current ones just have a single 8pin splittable to 2 4pin connector.
Gaming Rig:
HTPC Rig:
Old 15-06-2011, 07:11 PM   #24 (permalink)
ok my doubts get cleared regarding PSU. and for this i have postponed the buying for 1 day. thanks to all .
But what about the picture issue. pls help out that too.
Old 15-06-2011, 07:40 PM   #25 (permalink)
Dust in the Wind
Skud's Avatar
Check the settings of IE8 and KIS. May be something there.
Gaming Rig:
HTPC Rig:
Old 15-06-2011, 08:39 PM   #26 (permalink)
Super Moderator
asingh's Avatar
Try Opera.
Old 15-06-2011, 08:44 PM   #27 (permalink)
There is absolutely no problem in IE8 or KIS 2011setings as i can clearly remember that this prob has started only a few days back.I cannot see the pics which i have posted long before in TDF but that time it was clearly visible with kis 2011 & ie8. Moreover, i can see the picture clearly when i attach it in another forum.(attach pic)
So the prob is with my ID, i suppose.
Requesting moderators to check .
One more point: two days back i posted a thread in BAZAR section and topgear has blocked that thread for an inevitable reason and i have given three days time to correcvt that. has something occured from there?
Old 16-06-2011, 12:07 AM   #28 (permalink)
Super Moderator
asingh's Avatar
Why dont you post on photobucket, and host it here.
You sales thread did not comply with the rules.
Old 16-06-2011, 12:59 AM   #29 (permalink)
how to do that?
but the problem is not solved. doing photobucket is bypassing the actual problem i think.
this i have underdstood. since i am busy in buying the PSU and sunday is my only holiday i do not think i will be able to post the hdtune report before that.
Old 16-06-2011, 01:17 AM   #30 (permalink)
sriharsha_madineni's Avatar
Regarding your doubts about the pins you get, this might help.
Bought the same last year
Post your latest Purchase
If at all there is a change in the new batch of VX450, I can confirm it coz my friend will be getting his Vx450 tomorrow.
[Intel E8400]+[Intel DP35DP]+[4GB DDR2]+[GTX 560Ti]+[Corsair VX450]+[Altec Lansing VS3251R 5.1]+[DELL S2409W]+[Logitech MX-518] [iPod Touch 32GB] [iPhone 4 16GB] [Galaxy S II] [Sony Vaio EB26]
sriharsha_madineni is online now   Reply With Quote
- by c4u
