Old 14-06-2011, 11:23 AM   #1 (permalink)
Default [SOLVED] Everytime when pc starts need to press F1
Need help here. Recently my motherboard crashed so i got Biostar N68S, the issue is that when i start. It ask to press F1 to load window XP. How do i fix this issue?
rock_dj is offline
Old 14-06-2011, 11:33 AM   #2 (permalink)
Default Re: Everytime when pc starts need to press F1
what is the error msg ?
like in pic floppy disk fail
AMD Phenom II X6 1055T ,Benq G2220HD 22 ,GIGABYTE GA-880GM-UD2H ,COOLER MASTER Elite 310 ,CORSAIR 2GB 240-Pin DDR3 X3[6GB] , FSP Saga II 500 W HD 5750 . Hyper 212+ OS :Win 7 64 bit
Rajesh345 is offline
Old 14-06-2011, 12:31 PM   #3 (permalink)
abhidev's Avatar
ur floppy drive is not connected properly.....
Core 2 duo E4500 2.2gHz , ASUS P5GCMX , 3GB Transcend , Corsair VX 550w, MSI R5770 HAWK Edition 1GB, CM HAF-922, LG W2243T 21.5" LCD, I-Ball Baton
abhidev is online now
Old 14-06-2011, 12:40 PM   #4 (permalink)
Tech.Masti's Avatar
change BIOS battery.....
disable floppy from bios.....
this will solve the problem i think.....
Tech.Masti is offline
Old 15-06-2011, 11:16 AM   #5 (permalink)
Thanks guys...with your help. I got it done. You're right. After disabling floppy from the bios. No F1 issue. Tons of thanks to all you guys for your wonderfull & quick response and support!
rock_dj is offline
- by c4u
